A way to edit the Volume in seq view by default?
rockman413
Post by rockman413 »
To me, the only place I know to edit/view volume automation for tracks is the sequence view, but I have to right click add-volume everytime for a new track in order to edit/view its volume automation, is there a way to do that by default?
macbook pro 10.10, 2.5G,16G ram,256G SSD
Phil O
Re: A way to edit the Volume in seq view by default?
Post by Phil O »
I'm not sure how you're doing this. Where do you right-click to add volume automation to a track?
rockman413
Phil O wrote:I'm not sure how you're doing this. Where do you right-click to add volume automation to a track?
Just right click on the contents of track, insert volume then I can edit volume.
Is there a better way for everybody here to edit/view volume of all the tracks ?
reedster
Post by reedster »
What about Grouping the tracks and checking Set Active Layer in the group Custom dialog ?
MacBook Pro 9,1 15" 16gb | 10.12.4 | DP 9.13 | xAir | NI | WIVI | Garritan | Izotope | Bidule
rockman413
reedster wrote:What about Grouping the tracks and checking Set Active Layer in the group Custom dialog ?
It works, but not for new tracks
Post by Shooshie »
I think you've pointed out a slight weakness in the new "Lanes" feature. It would be nice if there were a "Lanes Setup," that works like Automation Setup, with defaults and overrides for what is normally set up to view/record for any/all tracks. I like Lanes very much as they are, but that would make them a lot better, IMO.
If no volume or other data exists your options are to insert, as you described, paste a volume value, or... drum roll please... have the default for the pencil tool be cc#7. Then click the "p" key. The cursor becomes a pencil and you can click in the continuous data area w/the value you desire.
2013 Mac Pro 32GB RAM
