De-Install 9.1 and move back to 9.02
Does anyone know of an easy way to do this, without major hassles or time-machine.
Also without having to rebuild all of my preferences, etc.
I do own app-zapper, if that would help?
Re: De-Install 9.1 and move back to 9.02
You can have both versions installed and running if you want. Rename 9.1 by adding the .1 to the name. Download and install 9.02 — it's still available.
http://motu.com/download/download_match ... oduct_id=1
Otherwise, you can trash 9.1 and reinstall 9.02.
You may not need to trash the preferences unless you set some that affect 9.02. If there's a problem, go ahead but, if not, leave them alone.
You shouldn't have to remove 9.1 completely. There are detailed instructions for doing so in another thread if necessary.
9.1 is really that bad for you?
http://www.davepolich.com
I noticed that on my MBP, where I installed 9.1, and it overwrote 9.02, the preference file still has a "last opened" and "modified" date from prior to the 9.1 installation. I guess if 9.1 used a different preference file, it would have written a new one, or overwritten the old one.mikehalloran wrote:You may not need to trash the preferences unless you set some that affect 9.02. If there's a problem, go ahead but, if not, leave them alone.
Yes I'm going back to 9.02 for the way it handles VIs.
I always get sick of all of the gloom and doom posts whenever a new version of ANY software comes out, but in this case, I was finishing a project the past three days and was on 9.1 for three straight 10-hour days.
For me, the whole VI thing was really a problem, considerably complicating and delaying work-flow.
Lot's of need for constant work-arounds...the opposite of transparency.
Please let me say that 9.1 may be a FABULOUS improvement for others, though.
Everybody uses these DAWs in such unique, weird, personal ways that one person's problems may never even be seen by another user, and 9.1 might be a huge, longed-for improvement.
Sorry you are having trouble. Which VI's are problems
for you?
I have experienced some heavy CPU load
with SOME older Kontakt instruments that
havent been updated by their creators in years.
Other Kontakt instruments load and play
without any CPU overload at all. Most of my
VI's play with negligible latency at 512, zero
latency at 256 or lower. Except for Trillian,
that still requires buffers set at 256 here to
play without latency.
Same story for Arturia Matrix V3 and Farfisa
V..these load up the CPU to about 50% at
256 and require 256 to play with no latency.
But their Oberheim SEM V plays fine at 512
with very little CPU usage.
My point is, I feel MOTU delivered the goods
with 9.1. I'm not going back to 9.02. Any problems
I have with VI's, I ascribe to the vendirs who
authored them and not MOTU, who couldnt
possibly test every plugin and VI on every
possible system configuration.
for you?
It is all VE Pro and Kontakt, and a mix of mostly new and a few old Kontakt instruments.
I also have a problem with Stylus not triggering mid-loop.
Finally, the sustain-pedal problems with everything that uses a sustain pedal (including Omnisphere).
Again, if 9.1 works for you, I say GREAT!
Whoever's problems these are (MOTU or third-party), I hope they get them fixed because I would definitely love to upgrade.
The new SMPTE plug-in alone would be worth it!
Someone posted in the "DP 9.1 is Here!" threadabout setting something in VE Pro to "4"...or maybe its something in the DP buffer settings page...wasn't exactly clear, but that might help solve the issue.JSmith1234567 wrote:It is all VE Pro and Kontakt, and a mix of mostly new and a few old Kontakt instruments.
Speaking for myself, I bailed on VE Pro sometime back, it was just too buggy for me. Same with East West - their Play engine is still buggy. I'm guessing VE Pro has not been updated to work with DP 9.1.
I'm not experiencing the sustain pedal issue with anything. Here's a thought though - check your pedal's polarity switch, if it has one. It may be that it got reversed. Or your sustain pedal itself may have a short. Also, try disabling Event Chasing (under the "Setup" menu). I explained this a bit more in my reply on this thread:
viewtopic.php?f=26&t=62126&p=529393#p529393
Set buffer in VE Pro to 4. At 2 it's does not work at 4 it works fine
waxman
Thanks. I don't use VE Pro but it's nice to know a roll back to DP 9.01 is overkill if one simply needs to change a simple setting to make it compatible with VE. That's a good thing to keep in mind in terms of other VI "problems" that might crop up for others.waxman wrote:Set buffer in VE Pro to 4. At 2 it's does not work at 4 it works fine
I did try the VE Pro 4-buffer solution but it didn't help with the sustain-pedal thing.
- toodamnhip
When I ran buffers at 4 on VE, it lagged behind the beat. Supposed to have latency comp but I run so many busses and master bus compressors etc, I betcha there’s a confusion until a DP or VE update. I dont think latency comp is right.
What about things like bundles when going back? Or any other prefs? Just install 9.02 and voila?
Mac Pro (Late 2013
2.7 GHz 12-Core Intel Xeon E5
64 GB 1866 MHz DDR3
Mojave
DP 10.13
MOTU 8pre, MTP AV, 828 mkII
64 GB 1866 MHz DDR3
Mojave
DP 10.13
I am not an expert on this subject by any stretch of the imagination, but here is what I did...
I used an app called "AppZapper" to get rid of DP and supposedly it gets rid of everything related to DP automatically.
I then installed 9.02 from the old install that was still in my downloads folder.
After I installed, I opened up the library window in the finder.
I went to last Wednesday's time machine back-up folder, opened up the old library in another window.
Then I just dragged and replaced everything I could find that had to do with MOTU or DP.
The one weird thing is it seems like there are two libraries...one in the hard-drive directory path, one under "users", and it seemed, but I could be wrong, that it was the one under my name as user that needed to be replaced.
After all this, 9.02 came right back perfectly with all my prefs and settings and commands and bundles and whatever.
Hope this helps!
Hope this helps!
