Rename input column tracks window to change bundle?
Re-naming in the input column of the tracks window to change bundle would be helpful...
Yes?
No?
Yes?
No?
waxman
Re: Rename input column tracks window to change bundle?
It would be useful and a pretty elegant solution. If the bundles window and the pop-menus in the inputs and outputs list could be renamed with abbreviations and each would live update the other.
I'm with you on this one. We mentioned how it would make the TO a little more space efficient so you could see more (especially on a laptop monitor).
No. It would be better to have a panel that is not specific to a project where you can assign and save sets of custom names to device channels. Maybe somewhere in the lower reaches of the Setup menu where other hardware settings appear.waxman wrote:Re-naming in the input column of the tracks window to change bundle would be helpful...
Yes?
No?
That's a good point. Though, like clippings, I could see how having BOTH project-specific names and global/permanent names.
I wonder if this is best handled either at the OS/CoreAudio/AudioMIDI Setup level -- to name the i/o there. Or if the manufacturer could be approached to provide a device driver with short names.
Shift U is not the end of the world but it's one more break in the action. To be looking right at the Tracks Window and not being able to do anything about it is a drag... especially some long name like Maschine Studio channel 1 Port 4... that takes a lot of real estate. So I change it in the audio MIDI setting. Again it's right there? Why? Maybe the code to go out and change bundles and audio MIDI setting is not practical...
waxman
Exactly. There are so many ways you can have a break in the flow. And often, when we see larger updates, there are little workflow enhancements just like this. The things we do most often should take priority, but also things that let you optimize screen real estate should be things we only have to do ONCE!! With you 100% on this.
My understand is the CoreAudio driver publishers channel names that audio applications are supposed to be able to pick up and use. You see this explicitly in Logic. Perhaps if no names are provided they default to input1, etc.stubbsonic wrote: Or if the manufacturer could be approached to provide a device driver with short names.
