MasterWorks EQ Automation Behavior
Hey there........
Love the MW EQ. Has anyone else noticed that—while the gain control on the individual bands goes to +/-24dB, DP's automation controls will only let you go +/-20dB?
Am I doing something wrong?
Is there a work-around?
Re: MasterWorks EQ Automation Behavior
Rick, I'm using DP7.24, but I thought it couldn't hurt to mention that all the gain parameters top out at -20dB on my sytem. That includes the plug-in's GUI, the Sequence Editor window, and the Event List. I tried entering -24 in the Event List and it wouldn't accept that value. -20dB was the limit.
I'm on DP 9.02 and the gain controls in the MW EQ only go to +/- 20dB. Just checked it in DP 8.07 and got the same results as Tritone. Are you sure you're not looking at the scale on the graph (which goes to +/- 24dB when the 24 button is on)?
Phil
Phil
You are right, sir. I was looking at the scale. When I read the data display is clearly shows that +/- 20dB is the max.Phil O wrote:Are you sure you're not looking at the scale on the graph (which goes to +/- 24dB when the 24 button is on)?
Phil
OK—feeling stupid now.
Been there, done that. No problem, Rick. I just did the same thing in another thread. I hope nobody read my stupid post before I got a chance to delete it.Rick Cornish wrote:OK—feeling stupid now.
I'm still on 8, has the scale been corrected for each gain resolution in 9? It's been wrong for a long time.
Doug Williams
Tape Op issue 73
DP 11.31
Studio M1 Max OS12.7.3
MOTU 16A and Monitor 8
Tape Op issue 73
DP 11.31
How is it wrong? There are four scales: 3, 6, 12, and 24 dB. Each one seems correct as far as I can tell.
Phil
Phil
look at the dB range markings. If you switch around between ranges, the dB markings do all sorts of random stuff. In 3dB range I just got it to display 0 and +/-3 only, then +/-3 where +/-1.5 should be and +/-3 again at +/-3 (two 3 points!), then switching to 24 range and back to 3 range it displayed +/-12 at the +/-1.5 mark and +/-3 at the +/-3 mark. I've seen all sorts of similar incorrect displays, several different computers.
Doug Williams
Tape Op issue 73
DP 11.31
Tape Op issue 73
DP 11.31
Wow! Very strange. I've never noticed that behavior before, but after playing with it for a while, I got it to fail once. Closing and re-opening the window corrected it. I haven't been able to reproduce it, so it seems to be an intermittent problem. (But it DID happen once).
Phil
Phil
