record audio with external sync chops off beginning
sloiselle
Post by sloiselle »
Hi folks, am wondering if this is just how it is, or if there's a setting I don't understand. I have DP9 on a Macbook Pro running 10.10.5
I'm feeding 16 channels optical through an 828mk3, and feeding MIDI from a master clock into the MIDI in of an Ultralite. I set DP to lock to beat clock, and it does, and records all the tracks. But the first half-second or so of audio is never recorded. I've spent a ton of time looking through the manual and searching online, but finally gave up and posted the question here in case anyone can help.
Also, I can't find anything in the manual that really explains the "Configure Hardware Driver" window. There's a "Master Device" pulldown, and a "Clock Modes" with two pulldowns, if anyone knows where in the manual that info is, I'd sure appreciate it!
Re: record audio with external sync chops off beginning
sloiselle wrote:Hi folks, am wondering if this is just how it is, or if there's a setting I don't understand. I have DP9 on a Macbook Pro running 10.10.5
Don't know what to tell you about the missing audio. Maybe it requires a second to sync up the optical data? Maybe if you do a count-off it would get it all. Or, try expanding the soundbite (edge edit the leading edge) to see if the audio is there. I haven't seen that happen, so I can't be of a lot of help.
The manual info on the clock modes and master device, etc., is page 26 of the DP9 "Getting Started" manual.
