Reset all track to same vertical zoom size in Sequence Eidit
When editing, I sometimes drag tracks larger vertically to see better, but then I get different tracks at different vertical levels when I add other tracks with the track selector.
Is there a way to reset all tracks back to one same vertical size?
Thanks.
Thanks.
Re: Reset all track to same vertical zoom size in Sequence E
Quickest method for me is to use the CMD-arrow keys. Hold the Cmd key and tap the up arrow key until the zoom level is all the smallest. The. Tap cmd-arrow down to adjust to the size you like. About as fast as any key command and you don't have to do it too often (at least that works for me).
Hey thanks man!
That does it!!!
That does it!!!
- buzzsmith
If I'm understanding...
Another way is to hold the option key down and select "Size" (under the far right arrow on any track in the SE), pick a size and all of the currently visible tracks will snap to that size.
If you add another track, it will be the default size and not the modified sizes that were just performed.
Yamaha C7 Conservatory Grand
Hammond B-3 / Leslie 145
Focal Twin6 Be(s)
Focal Twin6 Be(s)
Another way is to select all the tracks, hold down the "W" key, and change the size on one track. It will change them all.
+1Killahurts wrote:Another way is to select all the tracks, hold down the "W" key, and change the size on one track. It will change them all.
Or hold down OPT key and drag one to size; all will follow.
I use this method all the time.HCMarkus wrote:Or hold down OPT key and drag one to size; all will follow.
What I prefer with the key command method is not having to touch the trackpad (haven't used my mouse In a month thanks to Shooshie).
No kidding? You're actually using a Magic Trackpad? Man, I'm impressed. I didn't think hell or high water would part you from your Logitech Performance MX. I keep my MX handy for those moments when Bluetooth isn't working or I'm having to work with a bare-bones OS for installation, upgrades, repairs, etc. If USB is working, so will Logitech. But these days I rarely need it. OS X, despite its shortcomings, has improved on that front. They seem to understand that the Trackpad has always got to talk to the machine, and it usually does.MIDI Life Crisis wrote:(haven't used my mouse In a month thanks to Shooshie).
Well, glad to hear that you're working with a Trackpad. Remember: for delicate moves requiring control, roll your finger rather than slide!
I love it when you talk dirty! May have to use that move tonight.Shooshie wrote:Remember: for delicate moves requiring control, roll your finger rather than slide!
Only when you want that pointer to move slowwww!MIDI Life Crisis wrote:I love it when you talk dirty! May have to use that move tonight.Shooshie wrote:Remember: for delicate moves requiring control, roll your finger rather than slide!
Now we're both gonna get demoted...
