Hey all. I have a Korg Volca Beats drum machine. I've been able to synch it to DP, such that when I hit start, the drum machine sequencer starts (and stops). Due to lack of MIDI out port on the thing, I'm planning to sequence the drums in DP, then send the MIDI notes to the drum machine. This, to me, seems the easier way to capture/edit multiple patterns over time.
Is there a way to filter out the star/stop MIDI messages, but let the notes go through for a given track? Once I'm sending notes, I don't want to drum machine sequencer to start with DP.
Drum machine do not send start/stop but notes
Re: Drum machine do not send start/stop but notes
How is it hooked up?
I don't see a usb port — is there one? If not, what interface are you using?
Volca Beats has MIDI in.. that's it. I have a Motu ultralite MIDI box, so the idea is to send it notes, but not have the thing's arpeggiator come on.
Ok, got it figured.
step 1: disable transmit sync from DP
step 2: change MIDI channel (not in manual, but same as Volca bass on youtube)
step 3. Find correct notes. Mine were all one octave lower than this list I found on the internet:
36 - C2 - Kick
38 - D2 - Snare
43 - G2 - Lo Tom
50 - D3 - Hi Tom
42 - F#2 - Closed Hat
46 - A#2 - Open Hat
39 - D#2 - Clap
75 - D#5 - Claves
67 - G4 - Agogo
49 - C#3 - Crash
36 - C2 - Kick
38 - D2 - Snare
43 - G2 - Lo Tom
50 - D3 - Hi Tom
46 - A#2 - Open Hat
39 - D#2 - Clap
75 - D#5 - Claves
67 - G4 - Agogo
49 - C#3 - Crash
