The Clock is ticking...
- supersonic
Hi Guys
I have recently had a close encounter with the Fourth Dimension Beings that switched my DP to 48kHz while the main converter (SSL AlphaLink connected via RME Madi USB Interface) was sending and singing that USB interface to 88.2 kHz. Unbeknownst to my perception the whole thing got recorded and sound quite good. Come home and the whole thing goes west. The speed is all wrong. My temporary solution is to record it back at the studio onto another analog converter on another machine (because as long as the conditions are met the sound is fine).
However, this brings a question.
Why didn't DP follow the sampling frequency, and how can one solve that problem if for any particular reason they are not able to go back to the same set-up again.
Music is movement in silence
Re: The Clock is ticking...
In the Soundbites mini window > convert audio file, there is a checkbox you can select that will "change only the recognized sample rate", and not actually convert the audio.
That's Killa, and it don't Hurt, KH!
- philbrown
In case that doesn't work, try Soundhack.
Soundhack almost always works in these cases to change the header back to the correct sample rate, although your issue may be more complicated than that.
http://www.soundhack.com
- supersonic
Which one did you mean?philbrown wrote:In case that doesn't work, try Soundhack.
- supersonic
I tried that right at the start and it didn't work but now that you have said it I will try a different frequency. The funny thins is that the files sound like 44.1 played at 48. But they are already at 88.2 except that they were clocked to 88.2 (go figure). What I did as a backup plan I sent the whole project via analog to a Fostex recorder and then back into a clean session at 48kHz. That kind of worked except that there were tiny little pops (sync issues) that I cleaned up with RX5 (Bless Izotope for that wonderful tool, it saved me a countless amount of times). I will try something different now and will let you know if it worked.Killahurts wrote:In the Soundbites mini window > convert audio file, there is a checkbox you can select that will "change only the recognized sample rate", and not actually convert the audio.
- philbrown
Sorry- looks like it's gone or maybe way past its prime. I think the actual app originally called Soundhack is at the very bottom of the Freeware page.philbrown wrote:In case that doesn't work, try Soundhack.
- supersonic
