Arranging Audio Bundles
Chris T
Post by Chris T »
I have a very large template incorporating hundreds of MIDI tracks, mostly controlling VEP instances on the same (Trashcan) Mac, which also controls 3 external Macs (2 Mac Minis, 1 older Intel Mac). All the VEP audio returns are routing directly into stereo audio tracks in DP (on the Trashcan). When I work, I have the appropriate VEP instanced instantiated (and the corresponding audio track enabled). I monitor through the appropriate stereo audio track (using monitor button), then, when I'm ready to print, I select the audio tracks I'm using in the mixing board, move all audio tracks from 'monitor' to 'record', then hit record. I then MIX the audio tracks (where I can work with my reverbs effects etc) and bounce to disk as a stereo Mix (or as separate audio stems if required).
My question is this:
My AUDIO BUNDLES are currently a bit of a mess. As I add new VIs etc to my template I then have to add the appropriate Audio Bundles for routing/recording. Is there a way to tidy up my Audio Bundles so that, for instance, all my strings are grouped together, synths together etc. Same goes for y Audio Busses etc. I have so many audio bundles that it would take hours to organize them efficiently, and then reorganize once I add new VIs. Is there a way to 'group' or 'mass-move' audio bundles so I can easily arrange and manage them as my template evolves?
thanks!
Main SYS: 12-Core New Mac Pro (Dec 2013), 64GB RAM, OS10.10, Apollo Quad Interface, 3xSSD work/sound drives in TB Enclosure, UAD Plugs, DP, VE PRO, All NI, All Spectrasonics, many libraries, VIs etc.
2nd SYS: Intel 8-Core Mac Pro (2007), 28GB RAM, OS10.7, MOTU PCI 424, 2408 interfaces (4), DP8.07, VE PRO, All NI, All Spectrasonics, many libraries, VIs etc.
2 Mac Minis (2011): Dual Quad, 16GB RAM running VE Pro, various libraries in Kontakt, G-Player, UVI.
Re: Arranging Audio Bundles
Search for posts on bundles by FMiguelez. He has mastered the technique of bundle construction.
Chris T
Post by Chris T »
Hi FMiguelez
Do you happen to still have those pictures of your Audio Bundles you posted in this Post?
http://www.motunation.com/forum/viewtop ... es#p523515
I'm curious to know how others organize their Audio Bundles - especially for those with large numbers of Audio tracks / Busses.
thanks
Chris T
Post by Chris T »
I'm still DP8 and am not able to update since i'm mid-project.
Does anyone know if there is a way to mass-move/arrange Audio Bundles?
AB feature is really useful but incredibly cumbersome when it comes to large templates and many inputs...
thanks!
Martini Hill
Post by Martini Hill »
Interested as well!
Sent from my XT1030 using Tapatalk
|l| OS X 10.8.5 ML |l| 2.8 GHz MacBook Pro-8GB RAM |l| DP 9.02 |l| VE Pro 5 |l|Motu MTP AV-#2 MIDI Express USB-#2 2408 Mk II |l| #2 Mackie 400f's |l| Peak Pro 7 |l| Waves 9.x |l| CLA Classic Compressors |l| MPX Master Tape |l| Vocal Rider |l| iZotope Stutter Edit |l| Omnisphere 2 |l| Mach5 2 |l| Sample Tank 2 |l| Sonik Synth 2 |l| Stylus RMX |l| VirHarmonic |l| Albion I |l| VE Pro 5 |l| Superior Drummer 2 |l| EZ Drummer |l| Drumcore 2.5 |l| Garritan Personal Orchestra |l| Many hardware synths.
Chris T
Post by Chris T »
I guess DP9 has not addressed this yet?....
I don't understand why DP can't:
1. Allow you to Mass-Move Audio bundles
2. When you create a new bundle, make it appear directly where you want it (i.e. below the highlighted bundle).
Both these features would save me DAYS if not WEEKS of work while I'm re-arranging my mammoth template.
Pleeease MOTU!...
