32 bit vs 64 bit
32 bit vs 64 bit
Feels like a stupid question for someone who's been using DP as long as I have, but... What are the benefits of 64 bit vs 32 bit in DP?
- FMiguelez
Re: 32 bit vs 64 bit
You can basically access more than 4 GB of RAM with the latter. I'm not sure what the limit is for 64 bits, but you won't be adding that much RAM anytime soon.
The memory addressing limits of 64 bit far exceed the RAM capacity of any known Macintosh.
How much RAM do you have? Ok, it's a whole lot more than that.I'm not sure what the limit is for 64 bits
64 bit is a REALLY BIG DEAL for VI's. Use that memory like a champ!
If not using VI's, not so much.
Thx everyone. Yes I use lots of VIs and Kontakt often crashes DP when I get too much going on. The only reason I'd been avoiding it is that I have plugs and VIs that I'd have to dump or upgrade. (and JBridge doesn't work on everything) Anyway thx again and I'm on it!
As others have stated, addressing more than 4GB of RAM is the most obvious advantage.
Another difference is that a different instruction set for 64bit memory addressing can improve performance. That's the case on iOS - thought I'd mention it, because the thread is about 64bit in general.
