DP's Song window for mastering??
- FMiguelez
Hello.
I'm stuck in traffic and annoyed. So all I can do right now is thinking, or stressing out that I still have like 1 hour left to get home [sigh].
So, I currently, I use the following workflow to master my music libraries:
- Import all Final Mixes and stems. Each gets one track.
- All these go to the master fader, where I automate a plugin chain for each song (a piece of cake with snapshots). I navigate with markers, very quickly.
Everything is fine and works great, as long as I don't want to change the order of the pieces. Yes. I can do this by navigating with the markers, but I was wondering if the Song window could be used successfully for this (to try different sets of orders via different songs)...
Would this be even possible?
I have used the Song window only a few times, for other things, and I don't remember how well automation behaves between chunks, and when putting everything back together.
So I take it I would have to make one chunk per piece, and then put them together in the Song window. Afterwards, I could convert all the chained songs into a master chunk with my preferred order, yes?
Should I bother? Should this work? It would be very nice!
I won't be able to try this until tomorrow night, so any caveats or ideas will be appreciated.
Re: DP's Song window for mastering??
You can work in the song window but that seems like a more clumsy method than staying inside a single sequence chunk.
When I'm mastering I don't use a Master Fader because I want to process each track separately. I don't use any automation when mastering. That would have been done in the mix stage. So each track has it's own plug-in chain. That makes moving the order of the songs around an easy task.
Dave
Dave
There are compelling reasons to use automation during mastering, as it can help with things like solving problems in one section that don't exist in other secctions.
- FMiguelez
I see...magicd wrote:You can work in the song window but that seems like a more clumsy method than staying inside a single sequence chunk.
Perhaps I should try your method. So instead of automating the plugins in the master fader for each piece, you simply duplicate your mastering chain for each track and set them there.
I definitely see how this allows you total freedom to move tracks around. The only slight tradeoff is the small extra-processing due to the duplicated mastering plugins.
Thank you Dave!
Agreed.stubbsonic wrote:There are compelling reasons to use automation during mastering, as it can help with things like solving problems in one section that don't exist in other secctions.
With my current method, it is a must.
Also, sometimes I also like doing a little macro-dynamics work on certain pieces. This can't be done at the mixing stage because it depends on how piece x sits among the other pieces (sometimes it's nice to lower or raise the intro, give the climax of a song a lift, lower the coda in one pice x so piece y doesn't seem to start too loud, etc).
DP uses plug-in pre rendering. That means the plug-ins are not using CPU resources if no audio is playing in the track.
You certainly can automate during mastering if that's what you want. And if you need to move a song in the track, the automation can be selected with the audio for the move.
Dave
Dave
- daniel.sneed
Just my two (or three) cents on this.
I generally set :
- a master fader on main output, with mastering dynamic plugs and the like (multiband comp, exciter, stereo widener, maximiser, dither...).
- one track for each song (one soundbite each). Marker at beginning and end of each song, including end silence if any.
- Trim and MW Eqaliser on each song track to keep levels and tone consistent across the whole album.
- in case level automation is required, I set an aux track, called sub-master. Every song track is then routed to the sub-master track, and the sub-master track is routed to the main output. Any level automation will be performed on this sub-master aux track.
Many listening of the whole album in continuity.
Also jumping from here to there, specially high and low level parts.
And, of course special attention required about going from one song to the next one.
It may take days and nights...
I generally set :
dAn Shakin' all over!
Dave
- Prime Mover
^ THIS. I most definitely automate during mastering, typically when a track has a few wildly different sections (as most of mine do) with different arrangements, it's often like mastering a few different songs. Also quiet acoustic intros and bridges, things like that.stubbsonic wrote:There are compelling reasons to use automation during mastering, as it can help with things like solving problems in one section that don't exist in other secctions.
Bob Katz has a whole section dedicated to ideas on automating, and how to use it while not going against the energy of the track.
That said, I know Magic Dave is a total pro... this just demonstrates that everyone as their own unique way of doing things, and there isn't one right way.
— Eric Barker
Eel House
Eel House
I like the point about automation above, and the point you made (later) about pre-rendering. I hadn't thought about that.magicd wrote:You can work in the song window but that seems like a more clumsy method than staying inside a single sequence chunk.
Dave
But however easy it is to change the order of songs with this method, isn't it easier to have each song in it's own sequence, each sequence with one track and it's own plugin chain, and change the order by dragging the sequences around? Or did I miss something in the above approach? I assume you're using various range selection methods and region commands to move the songs.
- FMiguelez
The more I think about it, the more I see how it should be an improvement from my current mastering method.
I will try mastering my next project with the Song window to see if I like it. So far I don't see any caveats, except that at first I thought one can not automate the master fader if it's in a V-Rack (to be accessible to all chunks). But if my memory serves me well, one can have a master fader per chunk, and it will always access those when in Song mode... Is this correct? Otherwise, any track or plugin automation would have to be in each track.
And then what happens? Once you have a preferred order, you can convert all the chunks in the Song into one continuous chunk, correct? If this is the case, does it also take the automation of the tracks and/or master tracks from all the chunks, and places it all correctly consolidated into this final one? I know it does so with tempo, but I don't know if it really works for automation...
I'm trying to make sense of everyone's posts, and the best I can figure is that we're just not all on the same page. When I think of mastering an album, I'm thinking of taking a series of 2-tracks (one per song) and setting them up in a series to make a unified whole of an album. You can do this in something like DSP-Quattro, which is really designed for that kind of thing, or you can do it in DP.
If you do it in DP, we're talking about:
The advantage to putting each song into its own track is that each song gets its own plugin chain, and you can tweak it however uniquely it needs to be tweaked. With either method, moving a song means selecting from marker to marker, then for all tracks making a cut, move the cursor to the new location, and paste.
If you choose to use the Song Window, the only advantage I can see is that you can reorder the songs quickly. It will be much more awkward to access each song for mastering. If you are considering doing this, let me make a suggestion: Use the Song Window to play with the order of the songs until you are happy with what you've got. Then save the Song to a Sequence, where each song is in its own track. Then the Song Window method at least becomes feasible as a PART of the operations of mastering, but not the home for the nitty-gritty work of mastering each track. Plugins, levels, and such will be done in the resulting Sequence Chunk, after you've ordered the songs in the Song Window.
So, to say it again briefly, the only real advantage I can see to using the Song Window method is in playing with song order for the album. It's ok to do that, but when you like your order, save as a Sequence, and continue mastering within a Sequence Chunk.
Maybe this will help make sense of what seemed to me like several points of view from different "pages", now brought together on the same page. Sequence Chunk mastering also leaves open the possibility of using automation, if you prefer, within a single Sequence, whether on one track per album, or on one-track per song.
There doesn't have to be any mystery or rule to the method you use. Just do what works for you for the time, circumstances and material you're working in.
I've actually gotten used to mastering in DSP-Quattro, after having originally done so in WaveBurner. There are lots of advantages to using one of those apps for mastering, though the material may warrant staying in DP for it. Again, it's up to you.
As always, I defer to those with more skill at this, such as Magic Dave or Bob Katz, or whichever guru you prefer.
- 1) Mastering a whole album in one Sequence Chunk (which I will refer to as Sequence)
- OR
- 1) loading each song into the same stereo track (or 5.1 track), demarcating each song by a Marker, for getting around from song to song with ease
2) loading each song into its own stereo track (and still using Markers to facilitate jumping around while working, or for moving songs)
Am I correct that DSP-Quattro doesn't do automation of effect parameters?
I don't know of any, but that doesn't mean anything, because I don't automate my mastering stuff, generally. I get that part taken care of in the mix, same as Magic Dave. If I had something I wanted to automate in the mastering, I'd probably automate that effect on the 2-track before exporting it to DSP-Quattro. Or just master in DP.stubbsonic wrote:Am I correct that DSP-Quattro doesn't do automation of effect parameters?
Shoosh
- FMiguelez
[EDIT]
I guess I was still sleepy, since the answer I posted here belonged to my OTHER thread...
Sorry about that! ]
Sorry about that! ]
- FMiguelez
Exactly, Shoosh. You nailed what I want to try, and I appreciate your suggestion.Shooshie wrote: If you choose to use the Song Window, the only advantage I can see is that you can reorder the songs quickly. It will be much more awkward to access each song for mastering. If you are considering doing this, let me make a suggestion: Use the Song Window to play with the order of the songs until you are happy with what you've got. Then save the Song to a Sequence, where each song is in its own track. Then the Song Window method at least becomes feasible as a PART of the operations of mastering, but not the home for the nitty-gritty work of mastering each track. Plugins, levels, and such will be done in the resulting Sequence Chunk, after you've ordered the songs in the Song Window.
But your suggestion is precisely what worries me a little...
Will DP really convert successfully all the automation from the Song window (once I have my preferred order) to a regular sequence one I settle on it?
(I know you suggested to automate on a regular sequence all my tracks once I settle on their order, but once I'm inside a chunk that belongs to a Song, I would be nice to be able to tweak or adjust there, since some of those adjustments (macro-dynamics) would depend on the order of the songs (a lifted intro, a dB less of a coda so the next song's intro sounds better, etc).
How about the opposite? Suppose I have everything mastered already into a regular chunk (what you called Sequence, above). But then I want to try a different song order. How easy would it be to turn this back into Song mode while retaining whatever automation I already have?
In short, will automation translate properly when switching from Song mode to regular chunks, and viceversa?
Unless it does it perfectly and reliably, it cold be a recipe for disaster, me thinks...
