Multi MIDI bouncing
Multi MIDI bouncing
Hello Members,
I have seen a similar post for this but it did not address my question. So I am asking here.
I use DP 7 but do not any external digital mixer. I use an 8 channel Presonus Mobile Firestudio as my sound interface. Currently all my DP instrument outputs route to Output Stream 1 1-2 (see screenshot).
https://www.dropbox.com/s/rmhjp8s6ziti7 ... .tiff?dl=0
When I load a single VST instance, say Kontakt 4, and load three different samples instruments in it (Berlin Piano, Bass, and Pad), I assign the three instruments to 3 different MIDI tracks.
When it comes time to bounce or even freeze, I need to do this 3 times (once for each MIDI track).
I tried to route the output of each MIDI instrument to different channels but they only show st.1 (2 ch. routed 1|2) and st.2 (2 ch. routed 3|4). I went into Bundles hoping I can create virtual outputs for each VST instance such that the sound of each instrument in the VST instance goes to a separate audio, but could not figure it quite out.
In this configuration, is there a quicker way to lay down the 3 MIDI tracks into 3 separate audio tracks?
Your help would be appreciated.
Adam
Adam
Re: Multi MIDI bouncing
Adam, I'm far from an expert on this - there are LOADZ of 'em on this forum! - but if you want to wind up with 3 separate tracks, I think you are going to have to make 3 bounces - - simply because, when you look at the Bounce window to make, for example, a .wav bounce, you can only select a single Input source for that bounce. So, even if you set up your VI to output to 3 differing locations, you'll have to do 3 bounces - each one selecting a differing Input.
guys?
guys?
Kurz Midiboard, MOTU MTP AV
https://vimeo.com/71580152
~me
~me
- doodles
You can either do 3 separate freezes, or:
set the 3 MIDI instruments outputs to different AUX outs. create 3 new stereo tracks, with the input on each set to the respective AUX outs. Then hit record.
2*5-core 3.46 Intel xeon (32 gigs RAM), 2*dual 2.5 (16 & 32 gigs RAM), DP 8.07, WAVES 9, Lexicon plugs, SoundToys, all Spectrasonics, NI Komplete 9, Vienna Ensemble (extended), LASS, Evolve, Symphobia, etc, Cinesamples, Arturia, cinestrings, all Project Sam
- buzzsmith
I like!doodles wrote:You can either do 3 separate freezes, or:
Yamaha C7 Conservatory Grand
Hammond B-3 / Leslie 145
Focal Twin6 Be(s)
Focal Twin6 Be(s)
I like this option a lot too. I just don't know how to set MIDI tracks to aux tracks. I know how to assign aux tracks to stereo tracks. Thank you for this idea!!!! Please note, 3 tracks is just an example number I use. My scores get as big as anyone else's with close 50+ tracks. So it would be nice to know of a way to audiofy the MIDI tracks quickly without freezing one at a time.
You don't set MIDI tracks to Aux tracks. You set the outputs of the Virtual Instrument to Aux Tracks.tunazzina wrote:I like this option a lot too. I just don't know how to set MIDI tracks to aux tracks.
E.g, create an Instrument track and have it showing in the Tracks window. Create a MIDI track and set its output to the Instrument. The MIDI track data now plays the Instrument, and Instrument probably outputs to your main Stereo Outs. Now click and hold on the output for the Instrument (in the Output column in the Track window. One option is "new Aux Track via new stereo bundle". Select that, and the output of the instrument goes to an Aux track, which in turn goes to the main Stereo outputs.
Now you can reroute the output of the Aux track via a bus to a new Audio track which can then record the output of the Instrument.
Note that if you have Instruments with multiple output pairs, you should use the Bundles window to set up the outputs past the first pair. Then route each of the output pairs to separate Aux tracks if you want to be able to bus and record pairs to separate Audio tracks.
There is a simpler way without Aux tracks: when you've done the above, you'll see busses created to route the audio from the Instrument, to the Aux, to the Audio track. Just use the busses to route directly from the Instrument output pairs to Audio tracks. Put the Audio track in monitoring mode by pressing the Mon button in that column in the Tracks window. (You have to do this so you can hear the output of the Instrument. The reason for using Aux tracks is they do not have to be in Monitor mode.)
Group the Audio tracks created above so they can all be set to record mode at the same time. When ready, set one of them to record, then press play, and you're done.
You can set up all this as you build the project, with one Audio track set for each output of each Instrument, or set it as a template if you use the same general set of Instruments for each project.
To reduce the screen clutter, use folders and track view options. In the early part of the project you can have the MIDI tracks showing, with the Audio hidden. The when ready to render the MIDI to audio, switch the view to show the audio tracks and hide the MIDI and Instruments. Using common track colours and track names for the MIDI and Audio versions of the tracks helps too.
Does this work when I have multiple samples loaded in one instance of an instrument? I open say Kontakt 4 instrument and within it say I load 5 different sample instruments. How can I route the sound coming from each sample to a different bus or aux?bayswater wrote:You don't set MIDI tracks to Aux tracks. You set the outputs of the Virtual Instrument to Aux Tracks.....tunazzina wrote:I like this option a lot too. I just don't know how to set MIDI tracks to aux tracks.
Inside Kontakt you route different instruments to difference outputs. You can then access these outputs in the routing to Aux and Audio channels.
That's what I said in my very original post I had trouble with. I can't see more than channel 1 and 2 in each MIDI sample inside a single instance of Kontakt.bayswater wrote:Inside Kontakt you route different instruments to difference outputs. You can then access these outputs in the routing to Aux and Audio channels.
Multi MIDI bouncing
I suggest that you read the Kontakt manual and/or go to the Native Instruments site and look there for help in routing an instrument's output to a channel in Kontakt's internal mixer and how that channel gets published to DP where it shows in the Bundles window to be routed internally in DP. The Bundles section of the DP User's Manual is a necessary read for understanding DP's extremely flexible routing capability. Understanding audio (and MIDI) routing in and between both DP and the VIs you are using, is essential for achieving the results you are looking for.
Frank Ferrucci
Frank Ferrucci
Frank Ferrucci
http://www.ferruccimusic.com
Here's a picture of a simplified setup for doing this. To record, arm the tracks and hit record. Each Kontakt instrument will record into it's corresponding track.tunazzina wrote:That's what I said in my very original post I had trouble with. I can't see more than channel 1 and 2 in each MIDI sample inside a single instance of Kontakt.bayswater wrote:Inside Kontakt you route different instruments to difference outputs. You can then access these outputs in the routing to Aux and Audio channels.
Link to larger version of this image: https://dl.dropboxusercontent.com/u/184 ... t-full.jpg
p.s. -- I just noticed that in my haste, I got the track names wrong, but that doesn't affect the way it works.
Chuck
iMac (Retina 4K, 21.5-inch, 2017)|| 16GB Ram || OS/X 10.14.6 || Motu 828MkII || Steinberg UR242 || DP8.07
Macbook Pro (Retina, 13-inch), 2.7 GHz i5, 8GB Ram
Chuck
What Frank said: In the Kontakt manual. Or google Kontakt output and the first thing that appears is this.tunazzina wrote:That's what I said in my very original post I had trouble with. I can't see more than channel 1 and 2 in each MIDI sample inside a single instance of Kontakt.bayswater wrote:Inside Kontakt you route different instruments to difference outputs. You can then access these outputs in the routing to Aux and Audio channels.
https://www.native-instruments.com/en/s ... sequencer/
Gentlemen. You all are ver helpful. Let me review your suggestions. I always thought I might be limited in terms of outputs because I do not have external digital mixer channels.
Thanks Bayswater, the link explains the KT side much better than I. And where I wrote KT Mixer it should have been Outputs sectionbayswater wrote:What Frank said: In the Kontakt manual. Or google Kontakt output and the first thing that appears is this.tunazzina wrote:That's what I said in my very original post I had trouble with. I can't see more than channel 1 and 2 in each MIDI sample inside a single instance of Kontakt.bayswater wrote:Inside Kontakt you route different instruments to difference outputs. You can then access these outputs in the routing to Aux and Audio channels.
Frank Ferrucci
Dear Members,
You have all been of great help. I followed your advice and the tutorials you pointed me to. Very happy to share that I was able to set up my routing for simultaneous audio recording of MIDI samples. This will shave off valuable time from my pre-mixing workflow.
Again, thank you so much guys!
Adam
Adam
