Set Soundbite Tempo—Any Suggestions Welcome
Hi.......
I've always had a challenge with what should be a fairly simple process, in importing a lengthy soundbite (a full track) and syncing it to my sequence (or vice-versa).
In this case, I'm tracking some stems to play along with when my old band gets back together next month to lighten the load on our keyboard player, who used to cover all that stuff live. Basic stuff—click on one channel for the drummer and horns/strings on the other to send to the house.
I've built a simple template in DP9 and want to bring in the original track, so I can simply "play along" and re-create the horn and string parts in my VIs. Seems simple enough, right?
The first song I'm working on is Quincy Jones' "Stuff Like That". DP interprets the average tempo as 120.94, but in truth it's closer to 120. Surprisingly, the tempo on the track drifts pretty significantly.... too much to average it. "Adjust soundbite to sequence tempo" produces garbage. I suppose I could "adjust beats" for the whole 6:18 track, but what I'd have then is a sequence that drifts along with the track when what I want is a track that conforms to a consistent sequence tempo.
Any suggestions on how I can align this track to a steady tempo? Thanks in advance.
Re: Set Soundbite Tempo—Any Suggestions Welcome
As I understand it you are you going to use the imported audio for anything else than guide?
In this case I usually cut the soundbite where it starts to drift go 4 - 8 bars further cut than edge drag to make the selection fit to your grid - and so on...
Analog is great... We got both WOW and Flutter - what's your bias?
MOTU: DP9 - 2 x MachV - 2 x MX4 - 2 x 1296 - 2 x 896HD - 1 x UltraLite AVB - 1 x MOTU Monitor 8 - 1 x 24i - 3 x MTP AV | UA Apollo Quad | UA Arrow | SSL 2+ || Digi 002Rack | Mackie control + expanders | UAD-2 PCIe card | 2 x Mac Pro | Mac Mini Late 2018 | OS X 10.14.6
Thanks, Basstrup. Yes—the imported track is for use as a guide track only. Your idea is as good as anything I've thought of—and considerably easier. Thanks!
- FMiguelez
You should try using Record Beats and then Adjust Beats.
If all you want is a tempo map synced to your track, I'd say this is the best and easiest way to do it hands down, especially if the tempo varies.
Your tempo map will be as precise as your tapping, which you can tweak to perfection if you need to after-the-fact.
Thanks, FMiguelez.
What you describe will bring things together, but I'll have the opposite of what I want, tempo-wise; which would be a sequence that follows the tempo variations of my guide track instead of a guide track that's synced to my sequence tempo.
If I map the tempos, I wonder if there's a way to associate that tempo map as the tempo(s) of the soundbite. If so, I could then set a consistent tempo for the sequence and Set Soundbite to Sequence Tempo. Never tried that with a soundbite that had an intricate tempo map. Does anyone know if that works?
There are two commands: Adjust Soundbite to Sequence Tempos, and Adjust Sequence to Soundbite Tempo. If you want a project with a tempo map that follows the guide track, you do what FM says with Adjust Beats applied to the guide track audio, then apply the latter command. If the guide track has good transients at beats, DP will detect them, and you can edit them in the Sound Editor to fine tune the timing.Rick Cornish wrote:I'll have the opposite of what I want, tempo-wise; which would be a sequence that follows the tempo variations of my guide track instead of a guide track that's synced to my sequence tempo.
I've found it easier to record a new audio track with something like a hat sample that follows the beat of the guide track, and then use that Soundbite in the "Adjust" command instead of the actual guide track, and not bother at all with Record or Adjust Beats. DP is not that good at detecting a varying tempo in a more complex audio track. (not that other DAWs are any better at it)
- FMiguelez
Nice!bayswater wrote: I've found it easier to record a new audio track with something like a hat sample that follows the beat of the guide track, and then use that Soundbite in the "Adjust" command instead of the actual guide track, and not bother at all with Record or Adjust Beats. DP is not that good at detecting a varying tempo in a more complex audio track. (not that other DAWs are any better at it)
I'll try that next time. Thanks for the tip
Just don't forget to apply the Analyze Soundbite Tempo command to the new recording, if it doesn't get done automatically.FMiguelez wrote:Nice!bayswater wrote: I've found it easier to record a new audio track with something like a hat sample that follows the beat of the guide track, and then use that Soundbite in the "Adjust" command instead of the actual guide track, and not bother at all with Record or Adjust Beats. DP is not that good at detecting a varying tempo in a more complex audio track. (not that other DAWs are any better at it)
