BFD 3 drum plug in for DP - install trouble
Hi - anyone using BFD3? I think the installer put files in weird places and so the plugin is finding it impossible to find locate and load drums. I'd appreciate talking with anyone who has a successful installation. Maybe I can check the file placement with you.
Rich
Rich
Re: BFD 3 drum plug in for DP - install trouble
Yes I use BFD 3... I put the sounds on another disk drive 7200 RPM... The installer prompts you to do on where to put the content. There are also sections in the program where you can look for the sound sources. Did it install on your computer or your external drive?
waxman
Hey, Waxman -waxman wrote:Yes I use BFD 3... I put the sounds on another disk drive 7200 RPM... The installer prompts you to do on where to put the content. There are also sections in the program where you can look for the sound sources. Did it install on your computer or your external drive?
Thanks for responding ...
The problem I am having is that the installer did something buggy. First of all, it didn't ask me where I wanted the flies. It just put them in some weird places. Some folders (like the Kit configurations) are in a subfolder inside of the Documents folder (which makes sense) but a bunch of other folders - including the audio - are buried way the hell out about 8 or 9 subfolders deep in the Downloads folder. The little app that scans for the sounds couldn't even find those suckers, even after I pointed it there.
So I made a new nest of folders on my 7200 hard drive called "FXpansion -> BFD3 -> Audio, and in the last one I have all the audio kits 1-7 and percussion kit. But the scanner won't find THAT at all! Just ignores it completely.
I was figuring that if I could find someone with BFD3 like you, I could get a screen shot of where these folders all belong, I could put them there manually, and then the app might work.
Thoughts?
THANS again! I am going nuts.
BFD3 is real picky about where things get installed. When I did my install (I also had BFD2 installed) I followed the instructions fxpansion said to do to the letter. Certain things have to nest in certain places. My samples drive is an external drive. Unfortunately I don't have a photo sharing account anywheres so I can't post a screenshot but I'll describe where my files are. The samples (aka BFD3 Core Library) path is: samples/BFD3 Core Library. In that folder are two main folders. One called Audio which has folders labeled BFD 3 Kit 1 through BFD 3 Kit 7 and a folder labeled Percussion pieces. The other folder in the BFD 3 Core Library folder is labeled Grooves and that has two subfolders. One is labeled Jacques Mathisa and the other Platinum Samples.rmeitin wrote:Hey, Waxman -waxman wrote:Yes I use BFD 3... I put the sounds on another disk drive 7200 RPM... The installer prompts you to do on where to put the content. There are also sections in the program where you can look for the sound sources. Did it install on your computer or your external drive?
Thoughts?
Now for the BFD 3 program itself. Program in the Applications folder. In library/applications support there's an fxpansion folder with all kinds of stuff for BFD2, BFD3. And in MacHD/users/user name there's an fxpansion folder that has stuff for BFD2 and BFD3. The BFD 3 folder has subfolders marked Favourites, Grooves, Kits, Maps, Mixers, Playlists, Presets, Processed Drums, Profiles, Searches, Swing Templates (all user created bits and bobs).
Have you properly pointed BFD 3 itself in the 'setup content locations' under the tools menu? Note that you can have BFD scan selected folders, drives, etc. That way you can let the program do the grunt work for you.
I'd also suggest posting about this over on the fxpansion forums but be aware that there's a bug in the beta forum software they're running. If you have it setup to automatically send an email notification when there's been a reply to your post it currently isn't working so you have to go back periodically to check. The user base there is pretty knowledgeable.
What version of OSX are you running?
Hi Jack!
I have a MacBook Pro that's 2-3 years old. OS 10.9.5
Question- the audio files themselves - the ones containing the sounds - are .bfdca files, yes? They show up in the finder pane descriptor as "executable unix files." Do you have the same thing? Odd looking files. I was wondering whether maybe I downloaded the PC version by mistake, but I don't think so.
Also, to be clear, your external drive has a FOLDER on it called "samples?" so you get [hard drive name] ->samples -> BFD3 core library -> (audio folder and grooves folder)? Or -- is the NAME of your hard drive "samples" and when you open the drive up, you immediately see a folder called BFD3 core library?
ALSO! You said "And in MacHD/users/user name there's an fxpansion folder that has stuff for BFD2 and BFD3." - In my installation, that Fxpansion folder is in the "MacHD/users/user name/documents" folder. Can you confirm that yours is NOT in the documents folder in this similar path?
Thanks again for your help and detailed answer!
Jack helped me last time... and he is right if you start moving content around all kinds of gremlins start showing up.... the sounds, receipts, program, presets are all over the place. I still have doubles on a few pieces because I had install problems also... But I use it every day and love it...
waxman
Audio files - once one drills down to the actual samples mine have the extension .bfdlac which I believe is the extension for the new compression scheme fxpansion is using; the rock tambourine has the .wav extension. The .bfdca files are the compressed files in the installers. See this thread on the fxpansion site (you need not login) https://www.fxpansion.com/forum/viewtopic.php?t=7578008rmeitin wrote:Hi Jack!
The hard drive my samples are on is named 'samples' so that when I open that drive I see the BFD3 Core Library folder.
Lastly I made an error of omission in leaving 'documents' out of the chain. So the full chain is: Mac HD/users/username/documents/fxpansion
I recently deleted all of my BFD, UVI, SampleTank and Miroslav libraries and reinstalled to clean up paths and remove duplicates. Now DP and MachFve know where everything is and my system is about 300G leaner.
