HI
I want my track selector window to open on the left side in the consolidated window.
If it is on the right, how do I move it?
Also, what is the shortcut to open a list window?
Thank you.
Terry
move a window to other side
Re: move a window to other side
Choose "Show Left Sidebar" from DP's Window Menu. Shift-[ is the key command.Terry50 wrote: I want my track selector window to open on the left side in the consolidated window.
Then choose "Track Selector" from the drop down menu at the top left corner of the left sidebar
Select a track then hit Shift-ETerry50 wrote: Also, what is the shortcut to open a list window?
Mac Pro 'Nehalem' 2 x 2.66 Quad Core, 28GB, 10.11.6 || MacBook Pro 2.7 Intel Core i7 Retina, 16GB, 10.11.6 || MOTU 2408 Mk3, 828 Mk 2, MTP AV || DP 9.51 & 9.13, Mach 5 v3, MSI, Ethno2, MX4, VEPro6, all Spectrasonics, Kontakt ... and many of the other usual suspects.
http://www.thekeyboard.co.uk
Thanks a lot.
Good luck with your music.
