Just installed DP9.01 - was using 7.24... As in my subject line, DP doesn't see Native Instruments stuff or my Mach V 2.
Help.... Thanks
DP9.01 not seeing Mach V 2 or Kontakt 3
Re: DP9.01 not seeing Mach V 2 or Kontakt 3
Sounds like your running DP in 64bit mode. Your plug ins needs update to run in 64bit. In finder locate DP - select DP and hit get info and click open in 32bit
Analog is great... We got both WOW and Flutter - what's your bias?
MOTU: DP9 - 2 x MachV - 2 x MX4 - 2 x 1296 - 2 x 896HD - 1 x UltraLite AVB - 1 x MOTU Monitor 8 - 1 x 24i - 3 x MTP AV | UA Apollo Quad | UA Arrow | SSL 2+ || Digi 002Rack | Mackie control + expanders | UAD-2 PCIe card | 2 x Mac Pro | Mac Mini Late 2018 | OS X 10.14.6
Thanks. That worked!
