Understood, but it seemed to me that if one is going to the trouble of taking a 7 year old iMac apart, it's probably a good time to change the battery.mikehalloran wrote:You do not need to remove the screen unless replacing the NV RAM battery on the 2009–2010 (and only those years).
MOTU Press release from NAMM
Re: MOTU Press release from NAMM
Mine's not so ancient but DP9 already had, at least for me, more efficiency to run a lower buffer than I could for the same size project/session than I could in PT11.3.1 For example PT pretty much required 1024 and the same size piece of music I can run at 256 in DP9.01. I actually can run at 128 but 256 is more comfortable for the machine.bayswater wrote:I came to the opposite conclusion. With latency reduction and pre-gen enhancements, I expect to be able to keep my ancient iMac a little longer.Tritonemusic wrote: Looks like I'll be needing a new computer soon because I just can't resist all of the great enhancements introduced since DP 7.24.
- guitardood
at only 30% CPU?!?!?From the MOTU PDF...
buffer set to an ultra-low 64 samples
...can't wait to get me some of that
________________________________________________________________________
Best,
Guitardood
Chuck Fletcher on Reverb Nation
Chuck Fletcher on Facebook
"Life is like a box of chocolates. You know, eventually you're going to get the one filled with alien-like nasty tasting goo and have to spit it out and say YUCK".
Best,
Guitardood
- SixStringGeek
What you said.HCMarkus wrote:They may have to pry my upgraded 2009 from my cold, dead hands.
DP 8.newest on MacPro 5,1 Dual Hex 3.33GHz 64G Ram, 3TB SSDs.
I understand that. I was just talking about my personal situation. I will not change my current system because it works very well for me.bayswater wrote:I came to the opposite conclusion. With latency reduction and pre-gen enhancements, I expect to be able to keep my ancient iMac a little longer.Tritonemusic wrote: Looks like I'll be needing a new computer soon because I just can't resist all of the great enhancements introduced since DP 7.24.
Ultimately, I'd like a brand new system while keeping the old one until I decide I no longer need the old one.
