Hi
Can you play samples that were recorded in different sample rates in the same DP project?
I normally use 44K but to record samples for Kontakt, I want to try 96K to see if there is a difference.
Thank you,
Terry
44k and 96k in the same DP project.
Re: 44k and 96k in the same DP project.
Not directly. DP will convert them for you.
But projects can only be ONE sample rate. I use 48/24 as my default.
