For some weird reason stuck notes have come back (in DP 8.07) using VE Pro and slave macs. Notes would stop when I stopped, but then start again if I rewound to start of sequence, even though the note shouldn't have been playing. (Event chasing, etc, all properly set). All set to run in real time (rather than pre-gen).
The lovely guys at Vienna suggested switching to MAS, rather than AU. I had always resisted this, as my template contains about 40 instances of VE Pro, so thought it would take too long to re-assign every sequence. But it turns out if you just disable AU version in prefs, then it automatically re-assigns the plug-ins in the sequence to the MAS ones. Woop!
So far, so good, and the stuck notes issue has gone away. (It'll probably re-appear later ) Just thought this might help anyone else in this situation...
Tip: Cure for fixing Stuck notes in VE Pro
- doodles
2*5-core 3.46 Intel xeon (32 gigs RAM), 2*dual 2.5 (16 & 32 gigs RAM), DP 8.07, WAVES 9, Lexicon plugs, SoundToys, all Spectrasonics, NI Komplete 9, Vienna Ensemble (extended), LASS, Evolve, Symphobia, etc, Cinesamples, Arturia, cinestrings, all Project Sam
Re: Tip: Cure for fixing Stuck notes in VE Pro
The MAS version was brilliantly designed. I just love it.
