In Praise of MOTU's De-Esser
Just finished mixing a vocal record.. de-essers are usually problematic for me, because they always seem best when used post whatever processing is on the vocal. Well, that means that the de-esser better be a transparent one, because you don't want to have to compromise the sound after you fought hard to EQ, compress, and whatever.
I have a few tools available for curing sibilance disorders, but my new favorite is MOTU's own De-Esser. You know a tool is powerful when you first turn it on and it's way, way too much. I love that. I can turn someone into a Castilian with the push of a button! Seriously, the parameter set is truly complete, and when it it is set up correctly, it is transparent to my ears. Any of you guys used it?
Re: In Praise of MOTU's De-Esser
ironically, I have never even tried this plugin,
ever since I parted with my analog DBX 902 de-essers, I have never been happy with any other de-esser, but you have piqued my interest with your post and I will give it a try,
thanks!
thanks!
- mhschmieder
It's actually very advanced, and quite transparent.
I mostly use de-essers to de-harsh cymbals and hi-hats, to de-harsh poorly recorded electric guitars (usually from sessions I wasn't in control of), and occasionally (though artifacts are hard to avoid) for DI bass tracks to improve their low end response. For those purposes I usually use Sonnox, as Fabrice Gabriel never ported Eiosis plug-ins (other than Air EQ) to 64-bits.
The MOTU De-esser, however, did pretty well on stringed instruments last week -- better than a lot of de-essers I've bought that weren't exactly free. Sony is the main one that has earned its keep; the others are mostly disappointments, but MOTU's surprised me when I brought it up in a session the other day as I had forgotten it's either rather newish or a redesign of an older MOTU plug. It's of a similar quality to the Dynamic EQ plug-in.
Yep, and as I've said other places, if it's not a vocal usage, compare against the dynamic EQ plug, usually one or the other will be the obvious winner.
Doug Williams
Tape Op issue 73
DP 11.31
Studio M1 Max OS12.7.3
MOTU 16A and Monitor 8
Tape Op issue 73
DP 11.31
Dynamic EQ is another great plugin!EMRR wrote:Yep, and as I've said other places, if it's not a vocal usage, compare against the dynamic EQ plug, usually one or the other will be the obvious winner.
- mhschmieder
FYI Eiosis has announced a re-release of their de-esser at NAMM today.
I haven't the time to look at it in depth, but the GUI looks entirely different from the old 32-bit version.
I do hope it works as well and has similar functionality and algorithms, as I have yet to find a de-esser that does as good a job as that one does on certain tasks (such as de-harshing hi-hats). Now that I use ribbon mics on cymbals, it's less of an issue though.
It wouldn't surprise me if the new GUI was inspired by MOTU's de-esser, based on a quick casual look.
I suspect the MOTU de-esser will still find itself being used, even alongside Eiosis, as MOTU really took a unique approach to theirs.
Reading this thread, I'm looking forward to playing with it this weekend. There's this old project…I suspect the MOTU de-esser will still find itself being used, even alongside Eiosis, as MOTU really took a unique approach to theirs
MOTU de-esser is one of best around. Also even you use it on the vocal track itself add another instance on an aux track before a verb, can help a verb sound smoother...
Analog is great... We got both WOW and Flutter - what's your bias?
MOTU: DP9 - 2 x MachV - 2 x MX4 - 2 x 1296 - 2 x 896HD - 1 x UltraLite AVB - 1 x MOTU Monitor 8 - 1 x 24i - 3 x MTP AV | UA Apollo Quad | UA Arrow | SSL 2+ || Digi 002Rack | Mackie control + expanders | UAD-2 PCIe card | 2 x Mac Pro | Mac Mini Late 2018 | OS X 10.14.6
That's a cool tip. THANKS!
Putting a de-esser with some look-ahead on a reverb input could allow some more "open" settings on the reverb's spectrum.
