OS error reported by File I/O:
File not found (-43)
Additional information:
/Volumes/DISKNAME/.TemporaryItems/folders.502/TemporaryItems/file_name.dp3474341268
These often have to do with folder permissions, but I have my permissions set to Read & Write, and the Project files save correctly into my Project folder.
This is more of annoyance than a problem, as it doesn't seem to do any harm besides popping up after I save.
Anybody know if there's a fix?
recurring save error message
recording: Mac Mini 2018 - 32GB RAM - 3.2 GHz 6-Core Intel Core i7 - two Focusrite Scarlett 18i20 - OS 12.7.4 - DP 11.23
mixing: MacPro7,1 - 256GB RAM - 2.7 GHz 24-Core Intel Xeon W - Focusrite Scarlett Solo - OS 12.7.4 - DP 11.23
Both computers: Kontakt Komplete 13 VIs and effects. Effects: FabFilter, Sonnox Oxford, SSL, PSP, UA, iZotope. VIs: Cherry Audio, AIR Tech, GForce, AAS, East-West, Garritan, Best Service, Kilohearts, Brainworx, UA
Re: recurring save error message
You need to chase the path using the info that shows up in the long name. See if that folder exists.
You don't mention the OS. Its important.
I think I've figured this out. I got into a habit of hitting Save while playing several times in a row, just to make sure that DP was saving. This wasn't an issue with DP8, but apparently DP9 doesn't like that. I've noticed that I only get that message when Saving quickly more than one time. Solution is to stop doing that.
