Custom Click Help
Custom Click Help
Can someone help me set up a particular rhythm in my click.
I've read the manual, the MOTU tip sheet, and also the 'tips thread' here, but I can't seem to type the right sequence in.
I'm finding DP VERY un-intuitive in this regard. I deals with notation elsewhere (selecting crotchets or quavers as a click option for example)... why can't it give the same simple notation options for a custom click???
Anyway, I'm trying to achieve a 9/8 pattern as follows :
crotchet - crotchet - crotchet - dotted crotchet
or for you Americans:
quarter - quarter - quarter - dotted quarter
or, for you guitarists
1,2 - 1,2 - 1,2 - 123
Can anyone help?
Can anyone help?
Mac Pro OSX 10.10.5
2 x 3.33 Ghz 6-Core Intel Xeon
42 GB 1066 MHz DDR3
DP 9.13
42 GB 1066 MHz DDR3
DP 9.13
Re: Custom Click Help
I typed a "2 2 2 3" and that seemed to do it.
Thank you. I was trying to add the suggested "/4" or "/2" at the end to denote durations.
I also then neglected the spaces between the digits!
Thanks again!!
Thanks again!!
Mac Pro OSX 10.10.5
42 GB 1066 MHz DDR3
DP 9.13
42 GB 1066 MHz DDR3
DP 9.13
- philbrown
I tried using this 'feature' about a month ago and don't think I've ever scratched my head at DP that much. I ended up building my own click from scratch from audio snippets. Not only is it convoluted but definitely seemed buggy as well. Seems like there's got to be a better way.
In defense of the concept, this is a pretty brilliant method for a piece that might change meters frequently. This way, it is much quicker to build your click at the same time you build your conductor track (adding meter changes). It will instantly respond to changes in tempo and shifts that are made in meter after the fact. Combined with the ability to trigger a separate sample for an accent and non-accent, you can make a pretty workable click track quickly- and not have to futz with it once it is setup.
A custom made MIDI track is more versatile for a click track, but requires edits if you change meters after the fact. A custom audio track is sonically more versatile, but limits your options in other ways.
- philbrown
Maybe I'm just not smart enough- I mean that literally, not sarcastically!stubbsonic wrote:In defense of the concept, this is a pretty brilliant method for a piece that might change meters frequently. This way, it is much quicker to build your click at the same time you build your conductor track (adding meter changes). It will instantly respond to changes in tempo and shifts that are made in meter after the fact. Combined with the ability to trigger a separate sample for an accent and non-accent, you can make a pretty workable click track quickly- and not have to futz with it once it is setup.
I tend to make custom clicks with Drum Editor and Model 12. It's just as easy IMO and the "grooves" can be saved as clippings. Stubsonic does have a point about meter changes, although I don't really see that as problem.
Phil
Phil
Agreed. MOTU's Custom Clicks is not easy or intuitive at first, but once you figure it out, there's nothing more flexible.stubbsonic wrote:In defense of the concept, this is a pretty brilliant method for a piece that might change meters frequently. This way, it is much quicker to build your click at the same time you build your conductor track (adding meter changes). It will instantly respond to changes in tempo and shifts that are made in meter after the fact. Combined with the ability to trigger a separate sample for an accent and non-accent, you can make a pretty workable click track quickly- and not have to futz with it once it is setup.
One thing that could help is to read the instructions very carefully. You MUST figure out what is representing what. It's not like you probably think at first glance. Once you see how they are representing things, you'll agree that it's pretty ingenious, but it's not intuitive. If you think it's extremely intuitive, you probably aren't using it right!
I've never found it to be buggy, and I've used it a lot. The bugs always turned out to be user error. (me)
PS: a clue: there are infinite ways to write each click pattern, if I recall correctly.
Agreed with philbrown, I think I might be too ADD for DPs click track..
Personally I think it's an area because it's so different than other DAWs that should have it's own video tutorials. Mostly I feel like I would have to spend a day wading through it to fully understand how it deciphers things. If it can change the metronome when meter changes happen it's worth doing. I'll probably do it at some point, but grabbing a VST drum machine is too easy for most metronome things.
