jellyson wrote:We logged the functions that worked and did not work. These extended functions of which we speak are for instance, in the "Global" Buttons section, most of the functions were "confused", executing something different than the MC documentation from MOTU. Additionally some aspects of the Transport extended buttons were a problem, such as nudge, marker, cycle, replace, etc.
Using the "MIDI Monitor" application we were able to identify the MIDI commands being executed, reported this list to Behringer as well as comparing this to a MC Protocol reference that MOTU supplied, and we find that many of the commands coming off the X-Touch are the wrong MIDI notes/commands, many of them shifted by just one note. But that shift is just enough to cause problems. And since the the X-Touch does not provide for any programming, there appears to be no means to address these mis-calls.
That was the problem with my SSL console/controller when I first got it. Took me weeks to figure it out. Fortunately there is a software utility for the SSL that allows me to program it for the many DAWs it supports. DP is not really one of those DAWs, but it uses MCU, and I was able to re-route the MCU commands to the proper format for DP.
Mackie Control was originally created for Logic, and the Mackie Control surfaces have the Logic layout as a default. This is still the default to this day, for all the MCU-based controllers like the SSL Matrix, and the Behringer.
How did I know how to reroute it for DP? In the old days, if you bought a Mackie Control, they gave you a (physical) overlay for DAWs other than Logic. I simply compared the two and manually set them to be correct:
