Does DP9 Have MIDI Input Assign?
- ggm1960
For performing live I've discovered that this is something that could be really useful for me and I can't think of any other reason that I would want to upgrade from ver 8.
MBP's, DP10, 828x's, MTP's
https://www.facebook.com/Meinfield-346702719450783/
Re: Does DP9 Have MIDI Input Assign?
Maybe I'm misinterpreting your question, but DP has always had the ability to assign a single controller to a MIDI track. It does not default to this however. Under the Studio menu bar option check Multi Record and all your various controllers can be assigned to specific tracks. I have no less than 6 MIDI devices so this would be a total deal breaker if I couldn't assign the Remote SL to a synth plug in, the 88 key to a piano in Kontakt, the Push pad controller to Maschine drum sounds etc.
- ggm1960
Hey thanks a bunch Michael, I'm gonna check this out right now!
- ggm1960
Thanks again so much for taking the time to post, this really changes everything! I'd always kind of wondered about it but since I'd always used MIDI with a MTP AV I was able to do the routings I wanted and didn't worry about it. Recently though I bought a new Roland FA-08 and to get it to change studio sets it turned out that I had to connect it through USB which threw my "system" for a loop. Now however, I'll be able to consolidate a bit more and have even more control over these things than I used to. This really makes my day!Michael Canavan wrote:Maybe I'm misinterpreting your question, but DP has always had the ability to assign a single controller to a MIDI track. It does not default to this however. Under the Studio menu bar option check Multi Record and all your various controllers can be assigned to specific tracks. I have no less than 6 MIDI devices so this would be a total deal breaker if I couldn't assign the Remote SL to a synth plug in, the 88 key to a piano in Kontakt, the Push pad controller to Maschine drum sounds etc.
Greg
Hey believe me DP like all complex pieces of software has had features that eluded me in the past.
Recently I figured out that there are default key commands for changing the edit grid resolution in the MIDI editor. I was looking for quantize grid....
