Hi if I switch to multi record, even I didn't touch the faders of my MIDI controller, when I record, I can get MIDI cc like volume, others... But when switch off multi record, everything will be fine....
Because I use MIDI local pipe for vienna ensemble pro instruments, I have to use multi record. I tried to define "any" of input in non-multi-record mode, no result.
I tried to remap MIDI device, not working, even I remap a MIDI source to none, when I open the remap MIDI device again, it still remap that MIDI source to something. Is this a bug ?
Multi-Record mode let me record unwanted controller infomati
macbook pro 10.10, 2.5G,16G ram,256G SSD
Re: Multi-Record mode let me record unwanted controller info
Check your MIDI monitor to see what is sending the data and fix it at the source.
- philbrown
There's a MIDI monitor built into DP
I'll try that.
Anyone has tested that REMAP MIDI DEVICE? remap the MIDI source to define the input any?
