Model 12 outputs missing?
I am attempting to use an aux track for a model 12 drum. The drop down output menu on the MIDI track only offers model 12-1-in. I'm messing with bundles but must be missing something. I know I've done this before. Thanks.
iMac 27" 4.2 GHz i7 1TB SSD. 40 GB RAM. Apogee One.
Re: Model 12 outputs missing?
If I'm understanding your situation, you are confusing the MIDI routing with the audio routing.
You want to set the output of the MIDI track to send notes to the VI that is Model 12. That is so your Model 12 is "listening" to your MIDI track and playing your part for you.
Then look in your tracks list for the Instrument Track of the Model 12, and assign the output of that to any stereo bus pair you like (From example Stereo Bus 3 & 4).
Now go to your Aux track's input and assign that same bus pair as the input for your Aux. Set the Aux tracks output to wherever that should go.
I know it seems a little round-about, but it makes some other tasks easier to have it work this way.
