Hi
My macbook pro is the latest 15', should be have enough CPU power and 16 GB for DP. However, DP often appears to be running significantly slowly or reponding slowly, or low at performance under these circumanstances like
when you press shortcut to move up or down a note
when you press windowset shortcut, it displays like it's not stable
when you record MIDI in a track, the cursor do not go as smooth as when you're not recording
Etc.
Has anyone met these occasions? Or it's just me?
[/code]
Low/Slow Performance when these occasion, have you met any?
macbook pro 10.10, 2.5G,16G ram,256G SSD
