How to glue/merge MIDI clips?
How to glue/merge several MIDI clips into one region on a track? I'm sorry I looked at the manual, maybe because of my english is not good enough, I didn't find it....
macbook pro 10.10, 2.5G,16G ram,256G SSD
Re: How to glue/merge MIDI clips?
If you have several tracks, and you want to bring them together, the process depends on how or if the parts overlap.
If they don't overlap, you can just drag the clips into one track using the Tracks Overview window.
If they do overlap, what I do is first select the region I want to merge. If it is the entire track, my quick way of doing this is just to do a COMMAND-A to select all, then I just click on the source track-name that I want to use. Then I either copy or cut.
Then I select the destination track (by the track name), and use COMMAND-M, to merge the data into that destination.
