One key to open/Hide all plug-ins?
One key to open/Hide all instrument or effects plug-ins, or a selected track's instrument plugins? Can we set it as a shortcuts?
macbook pro 10.10, 2.5G,16G ram,256G SSD
Re: One key to open/Hide all plug-ins?
Using Spaces, you can just leave them open. Unless, of course, you want them to pre-render. There's a key for adding a plugin, but I don't know of one to open all plugins on a track.
Allow me to hook you up with a secret "cheat sheet" for power users: print out the Commands Window. Be sure that all sections are open (possibly excepting the fonts options, which can go on for pages) and print out the whole thing. It can take upward of 28 pages, give or take a few. Most of my workflows and "secrets" come from perusing the Commands Window pages, which I also have printed as a PDF file, and I keep both the paper version and the PDF version handy at all times. I put together strings of commands and sometimes reprogram the keyboard shortcuts so that they are more sequential to use. When I change a shortcut or add one, I pencil it in on the paper version until I get enough to justify printing it again.
At one time I even had index tabs on all the sections.
Just a word to the wise.
- Robert Randolph
Why would you want to do this?rockman413 wrote:One key to open/Hide all instrument or effects plug-ins, or a selected track's instrument plugins? Can we set it as a shortcuts?
- Guitar Gaz
I wonder this about many of these questions - how to do everything by just one click seems to be the common thread.Robert Randolph wrote:Why would you want to do this?rockman413 wrote:One key to open/Hide all instrument or effects plug-ins, or a selected track's instrument plugins? Can we set it as a shortcuts?
Gary Shepherd
____________
____________
- Robert Randolph
Why wouldn't you want to do as many things as possible in one click? Seems totally reasonable to me.Guitar Gaz wrote:I wonder this about many of these questions - how to do everything by just one click seems to be the common thread.Robert Randolph wrote:Why would you want to do this?rockman413 wrote:One key to open/Hide all instrument or effects plug-ins, or a selected track's instrument plugins? Can we set it as a shortcuts?
I'm just curious if maybe there's some other way to achieve the end result he's after here.
Spaces is a great way to use, but not handy at all when you useDP in fullscreen mode.Shooshie wrote:Using Spaces, you can just leave them open. Unless, of course, you want them to pre-render. There's a key for adding a plugin, but I don't know of one to open all plugins on a track.
At one time I even had index tabs on all the sections.There are menu items that do not appear in this list, but between the menus and the commands, you've got pretty much the whole list of what you can tell DP to do. However, by putting them together in unique sequences, or by using sub-commands that you find in windows like the Search Window or Split Notes window, you can do amazing things that aren't documents in any way.
Can we open effects window in the cosolidate window?
- Robert Randolph
No, but you can use the on-top functionality in DP9 to permanently put a plugin in a place on the screen.rockman413 wrote: Can we open effects window in the cosolidate window?
And Spaces is specifically useful if you use DP in fullscreen mode, that's how Spaces was made to work. I don't think you understand Shooshie's suggestion fully.
Maybe. If I use DP in full screen, then i can't drag the effects window to another Space, it always stays in the same space as the main DP interfaceRobert Randolph wrote:No, but you can use the on-top functionality in DP9 to permanently put a plugin in a place on the screen.rockman413 wrote: Can we open effects window in the cosolidate window?
There's full screen and fullscreen. Spaces works with your windows sized to the full screen. DP has a "fullscreen" mode, but it's very limiting. Why would you want to do that? Spaces opens you up to all kinds of possibilities. Fullscreen limits you to one.
GOt it, you mean drag the window to full of screen. Fullscreen saves a little bit more space without the top menusShooshie wrote:There's full screen and fullscreen. Spaces works with your windows sized to the full screen. DP has a "fullscreen" mode, but it's very limiting. Why would you want to do that? Spaces opens you up to all kinds of possibilities. Fullscreen limits you to one.
That top menu does not matter a lot, I've set my screen to work this way, thanks Shooshie!Shooshie wrote:There's full screen and fullscreen. Spaces works with your windows sized to the full screen. DP has a "fullscreen" mode, but it's very limiting. Why would you want to do that? Spaces opens you up to all kinds of possibilities. Fullscreen limits you to one.
