Freeze will include playback noises such as low buffer click
rockman413
Post by rockman413 »
Hi ,
Is freeze selected track like real time recording?
If yes, I assume that it will also include pops/clicks which is normal when you playback at a very low buffersize ?
macbook pro 10.10, 2.5G,16G ram,256G SSD
Re: Freeze will include playback noises such as low buffer c
So raise the buffer size...
2013 Mac Pro 32GB RAM
rockman413
MIDI Life Crisis wrote:So raise the buffer size...
It's a technical disscusion.
Rasie the buffer size will cuase other problems, like when you got over 100 tracks , you have to set buffer size large , maybe1024 samples, but that would cause delays/ drum tempo not synced perfectly.....
DP has plugin delay compensation. At least when everything is working correctly, all tracks are synchronized, regardless of the plugins. Some plugins don't report their latency properly, and then you have to correct them manually, but most of them do a good job of that.
