Hi there,
We can open/pop out a MIDI editor and put it in Space 2 or other monitor, but if we select something new in the track view, it will always open a new MIDI editor instead of switch that exisiting MIDI editor to edit the new selected track/region. How to let them sycn with each other?
Roc
How to Sync between MIDI editor and selection in track view
macbook pro 10.10, 2.5G,16G ram,256G SSD
Re: How to Sync between MIDI editor and selection in track v
Synchronize your windows so that they all follow the cursor.
When you want to go to the MIDI Edit Window, either switch to its Space, where it's waiting for you as you left it, but scrolled to the current measure or time marker. You can also use the keyboard command for the MIDI Editor.
However, I do not experience the problem you describe. I can double click any MIDI object in the Tracks Overview Window, and it goes right to the MIDI Editor Window that I've left open in Space 3, scrolled to the proper location. Works 1st time, every time.
I think you need to set your preferences for the multiple-MIDI-Editor.
- • Open the Preferences Window
• Go to EDITING / MIDI EDITING
• Look at MIDI Editor Options
• Set it for "Open one MIDI Editor for each sequence with all MIDI tracks"
Perfect!Shooshie wrote:Synchronize your windows so that they all follow the cursor.
I think you need to set your preferences for the multiple-MIDI-Editor.For me, this is the most efficient way to edit MIDI, anyway. I bugged MOTU for about 9 years to get that feature, which they finally put into DP 3.0 in January, 2001.
