How to scroll inside MIDI editor?
Hi !
When use the mouse wheel to scroll in MIDI editor, either it scroll to the top or to the bottom.... How can I scroll it slowly and find the MIDI notes I have in piano roll?
macbook pro 10.10, 2.5G,16G ram,256G SSD
- Guitar Gaz
Re: How to scroll inside MIDI editor?
keep left caps key pressed while using scroll wheel
Gary Shepherd
____________
iMac 27" 3.3 GHz Intel Core i5, 32 GB Ram, Monterey 12.7.4, 64 bit, Digital Performer 11.2, Studio One 6.5 Professional, Reason 11, Melodyne 5 Editor, Korg Legacy Wavestation and M1, Arturia minimoog V, Helix Native 3.72, Bias FX 2 Elite, Superior Drummer 3, EZkeys, EZbass, Nektar Panorama T4, Motu M4, Faderport 2018, Gibson Les Paul Standard, James Tyler Variax JTV-59 and other gear.
____________
Not sure what the problem is with your mouse, my doesn't do that. On the other hand, you can always use the scroll handle on the left side - just click and drag it.rockman413 wrote:Hi !
Chuck
iMac (Retina 4K, 21.5-inch, 2017)|| 16GB Ram || OS/X 10.14.6 || Motu 828MkII || Steinberg UR242 || DP8.07
Macbook Pro (Retina, 13-inch), 2.7 GHz i5, 8GB Ram
Chuck
What version? In DP 8 I had that problem with Trackpads and the Apple Magic mouse, but not with other devices. It's fixed in DP 9.rockman413 wrote:Hi !
DP9 on PC. I just tried DP9 on Mac, this problem is gone!! Is there a switch or setting for this?bayswater wrote:What version? In DP 8 I had that problem with Trackpads and the Apple Magic mouse, but not with other devices. It's fixed in DP 9.rockman413 wrote:Hi !
- Robert Randolph
It does not appear to be totally fixed in some Windows systems. It jumps from top to bottom for me in windows as well.bayswater wrote:What version? In DP 8 I had that problem with Trackpads and the Apple Magic mouse, but not with other devices. It's fixed in DP 9.rockman413 wrote:Hi !
Same system, same peripherals, it works fine in OS X.
I suppose that casts some doubt on the argument that it was an Apple issue and not a DP issue.
