Pitch Shifter Recommendation?
Does anyone have a recommendation for an audio pitch shifter?
I don't usually shift audio by more than a second or a third. I've tried DP's Spectral Effects, which usually sounds pretty bad, and DP's transpose function isn't usually much better to my ear. Perhaps I'm missing something, but I've never found a way to transpose audio cleanly within DP (time-stretch—yes, but transpose—no).
How are you guys doing it? Maybe using something within DP that I'm not seeing, or using something from a third party?
Thanks.
Thanks.
- doodles
Re: Pitch Shifter Recommendation?
lexicon = amazing
2*5-core 3.46 Intel xeon (32 gigs RAM), 2*dual 2.5 (16 & 32 gigs RAM), DP 8.07, WAVES 9, Lexicon plugs, SoundToys, all Spectrasonics, NI Komplete 9, Vienna Ensemble (extended), LASS, Evolve, Symphobia, etc, Cinesamples, Arturia, cinestrings, all Project Sam
IrcamLab TS = amazing too.
Also great for time stretching...
Mac Pro 'Nehalem' 2 x 2.66 Quad Core, 28GB, 10.11.6 || MacBook Pro 2.7 Intel Core i7 Retina, 16GB, 10.11.6 || MOTU 2408 Mk3, 828 Mk 2, MTP AV || DP 9.51 & 9.13, Mach 5 v3, MSI, Ethno2, MX4, VEPro6, all Spectrasonics, Kontakt ... and many of the other usual suspects.
http://www.thekeyboard.co.uk
Probably need to make some differentiation between polyphonic source material vs. monophonic source material. DP's pitch works well for single notes. Chords or mixes are a task for different software (see above).
Thanks—very good point.stubbsonic wrote:Probably need to make some differentiation between polyphonic source material vs. monophonic source material. DP's pitch works well for signal notes. Chords or mixes are a task for different software (see above).
IRCAM? Hmmmm.... haven't tried bring the audio into MachFive 3. Would MF3's IRCAM effects offer the same solution?davidh wrote:IrcamLab TS = amazing too.
Absolutely you can use MachFive 3 for high quality IRCAM pitch shifting.
Dave
Dave
Pitchwheel by Quickquack works reasonably well for a plugin. For something quality MachFive3's ICRAM is my go-to.
In case I am missing something, you are talking about a wholesale pitch shift and not harmonizing, correct?
Correct.mikehalloran wrote:In case I am missing something, you are talking about a wholesale pitch shift and not harmonizing, correct?
- Tesionman
I find that the AUpitch plugin from Apple isn't too bad.
Get Real Live Drum Tracks @ http://www.hugoribeiro.com
Macbook Pro | DP 10.13 | Motu 8Pre (x2) | Apogee Duet 2
Sonor Drums | Sabian Cymbals | Remo Drumheads | Vater Drumsticks
Looks like bringing samples into MachFive3 and pitch-shifting there is the way to go.
Thanks, everyone.
Thanks, everyone.
Without testing them all, I would guess that this is the method of choice. IRCAM's research has yielded some of the finest audio solutions in the digital world. I rarely have to do anything like this, but when I do, I use MachFive-3.Rick Cornish wrote:Looks like bringing samples into MachFive3 and pitch-shifting there is the way to go.
Thanks, everyone.
Shoosh
Out of curiosity: Is there a way to use MachFive 3 to, for example, timestretch/timecompress a 4-minute long file? Or is that sort of job solely the province of external solutions?
https://www.youtube.com/watch?v=Scz8Kh2Cd2gjloeb wrote:Out of curiosity: Is there a way to use MachFive 3 to, for example, timestretch/timecompress a 4-minute long file? Or is that sort of job solely the province of external solutions?
