ircam tools with DP9
Hey folks. Are all the ircam tool AU's loading and working with DP9?
Re: ircam tools with DP9
Labman,
I had to buy the upgrade from 1.x to version 3 to get it to work. I haven't had time to look into every plug yet, but if I remember correctly..
The reverbs worked.
The voice filter plugs, Trax (?), there seemed to be som trouble (might be my imagination though).
Hear, I just downloaded. Will install it tomorrow.
/B
The reverbs worked.
/B
Macmini M1 | Motu 828mk3 x 1 | 2 x Motu M64 & SSL XLogic Alpha-Link MADI AX | 2 x Motu MTP AV | OSX 12.6.x | DP 11.x | Mach5 3.x.x | 2xiLok | 2xUAD quad dsp card | Altiverb 7.x | SoundToys | Nomad factory | PSP | Arturia V-collection | Korg VI's |
and loads n' loads n' loads n' loads n' loads o' stuff.
Thanks B. I will look forward to hearing your experience.
Labman,
I got a little bit further today. First. Download the 3.3.6.xxxxx versions. They seems to fix all problem with the plugs. Also, if you have any 32-bit wrappers. Be sure to un-check all the 32-bit versions (unless you run @32-bit).
Haven't done too much except instantiate all the plugs, and run audio through it...
/B
/B
Nice. Thanks B. Will do the new ones and let 'er rip.
