2010 MacBook too slow for DP8 project??
- toodamnhip
Re: 2010 MacBook too slow for DP8 project??
Nice to watch James change his mind live and in real time. Sometimes this board is a true collaboration with everyone pitching in to help ...nice to see.
Mac Pro (Late 2013
2.7 GHz 12-Core Intel Xeon E5
64 GB 1866 MHz DDR3
Mojave
DP 10.13
MOTU 8pre, MTP AV, 828 mkII
64 GB 1866 MHz DDR3
Mojave
DP 10.13
I've used the OWC Data Doubler in a 2010 i5 MBP for the past 3 years. Works great! Currently using an SSD for OSX and apps, and a 7200 rpm for projects. The heat build up is something to be aware of but otherwise hasn't cause any problems.
2017 2.9 GHz MPB/1TB ssd; loaded 2012 i7 quadcore Mini, OS 10.15.5
DP 10.11, Logic 10.5.1, Silverface Apollo Quad/TB, K12UC, Falcon, Integra 7, MIDI guitars etc.
Well, I'm already booting of a Samsung 840 EVO for my main studio computer, so I'm not closed minded to SSDs. I just didn't want to pound a wire brad with a sledge hammer if it wasn't necessary to spend the money. This is an older MacBook.toodamnhip wrote:Nice to watch James change his mind live and in real time. Sometimes this board is a true collaboration with everyone pitching in to help ...nice to see.
BTW, did we ever arrive at whether it's good or bad to enabled Trim for OWC SSDs? I think OWC said don't do it, but the consensus was to go ahead.
What's your buffer set at? If you are just using the Macbook to playback I would set it to 1024.
My research results: enable.James Steele wrote:BTW, did we ever arrive at whether it's good or bad to enabled Trim for OWC SSDs? I think OWC said don't do it, but the consensus was to go ahead.
Naturally. That's what it was set at.rickorick wrote:What's your buffer set at? If you are just using the Macbook to playback I would set it to 1024.
I'm about to do an SSD brain swap in an '08 2.4 MBP, watching with interest. It's just too slow with current OS and a spinning drive, hope to see improvements. It has the same 4GB RAM limit officially, you can go to 6 but it's stupid expensive for a machine of this age, more than buying 16GB for a current machine. But ya know, I'm soliciting donations of compatible used 4GB RAM just in case! RAM is always maxed and virtual memory is having to make do with spinner speed as it stands now.
With the MBP and the last-gen G5 I retired last year, I could increase the number of sequences in a new project (lacking VI's or plugs) to a point at which DP would cease to function. It could be parked and adding another sequence would make the processing meter rise with each addition, until it maxed and would be in the red with no activity. 6-8 sequences was about the max I could ever safely load in one project. This sounds similar to what you are seeing, I hope we both get improvements.
Doug Williams
Tape Op issue 73
DP 11.31
Studio M1 Max OS12.7.3
MOTU 16A and Monitor 8
Tape Op issue 73
DP 11.31
My earlier caution about replacing the battery applies. I will get pictures of both our dead soldiers uploaded. The 2008 isn't as bad as the 2010 but neither is pretty. My son-in-law tells me that some 5 year old iPads and iPhones are doing it, too.
I think I may have a pair of 2G RAM modules for a 2008. I know I don't have a 4G. Yea, talk about crazy stupid on the price.
At least the 2008 is the removable battery, it's ready for its 3rd if all goes well. Seems like it would have more headroom for battery expansion before problems occurred.
Doug Williams
Tape Op issue 73
DP 11.31
Tape Op issue 73
DP 11.31
Update: the '08 2.4 MBP is noticeably faster than it was, usable in fact, and I could open a lot of apps and video files (stopped around 10 video, all in play loop, with a dozen apps) before there was any sign of stress. Previously opening anything at all was an exercise in patience. I haven't taken a spin with any DP projects yet, interested to see how that feels now. Lots of projects were too big to even open and play at all on this machine with the 7200RPM HD.
It's hard to imagine the battery expanding enough to impact the keyboard/pad above, but I can see it'a all much closer than I realized once it was torn down. Initial performance seems more than enough improved to justify battery expenditure.
Doug Williams
Tape Op issue 73
DP 11.31
Tape Op issue 73
DP 11.31
coming a little late to this, but you might want to consider using simple MP3's for your backing tracks. Put a click track on one channel and the audio on the other. Hit play on a simple MP3 playback device. Done.
Using DP or any other host to play MIDI and audio tracks opens up a whole lot of complications. What it does give you is the ability to remix the tracks live at the gig, if you have more than one instrument recorded, which admittedly can sometimes be an issue. I have found its not often an issue though, as backing tracks tended to be pretty simple for me.
Glad to hear you made your macbook faster anyway, sounds like a worthwhile thing to do either way.
I know a lot of people do it that way, however, I'm pretty much dependent on having the MIDI capabilities. I use the MacBook/DP to send patch changes to my MIDI Raider controller pedal that controls my guitar rig, so essentially my guitar rig is completely automated. I don't have to do the "tap dance" while I'm singing and playing guitar.dewdman42 wrote:coming a little late to this, but you might want to consider using simple MP3's for your backing tracks. Put a click track on one channel and the audio on the other. Hit play on a simple MP3 playback device. Done.
oh yea, I could see that being useful. If you're gonna play to a backing track anyway, then why not!
I got in from VT this morning. I'll try to get some battery pics posted this evening.
