I need to split a MIDI track into multiple tracks. The track has 4 parts, as in a horn section, but my VI only plays solo. Is there a plugin that can do this? Or some "magic" selection tool in DP that will allow me to "select" highest note, cut, paste, etc., repeat...
Thanks in advance.
Splitting MIDI track
Chuck
iMac (Retina 4K, 21.5-inch, 2017)|| 16GB Ram || OS/X 10.14.6 || Motu 828MkII || Steinberg UR242 || DP8.07
Macbook Pro (Retina, 13-inch), 2.7 GHz i5, 8GB Ram
Chuck
- philbrown
Re: Splitting MIDI track
Region>Split Notes
Thanks for that, looks like what I need, BUT it doesn't seem to be working correctly. The chords in the original are quantized, so they are precisely on the same "tick", yet when I use split "top 1 note of each chord", the resulting new track has all 4 notes, the original is left empty. No other criteria was specified.philbrown wrote:Region>Split Notes
I was using DP9, so I'm going back to 8.07 and see if it's the same.
Chuck
Chuck
- philbrown
Sounds like a bug. I never use that so I wouldn't know.cleamon wrote:Thanks for that, looks like what I need, BUT it doesn't seem to be working correctly. The chords in the original are quantized, so they are precisely on the same "tick", yet when I use split "top 1 note of each chord", the resulting new track has all 4 notes, the original is left empty. No other criteria was specified.philbrown wrote:Region>Split Notes
You might try Edit > Search.
Ok got it. Even though in the event list, all of my notes were EXACTLY on the same tick (i.e. 1:1:000) , apparently they were not. I used Region->DeFlam, then tried the region->Split, and it worked fine.philbrown wrote:Sounds like a bug. I never use that so I wouldn't know.cleamon wrote:Thanks for that, looks like what I need, BUT it doesn't seem to be working correctly. The chords in the original are quantized, so they are precisely on the same "tick", yet when I use split "top 1 note of each chord", the resulting new track has all 4 notes, the original is left empty. No other criteria was specified.philbrown wrote:Region>Split Notes
Chuck
Chuck
