How do you create legato in MIDI Editor
Musicmind
Post by Musicmind »
Hi
I'm looking for a simple solution to this common problem: I record a MIDI track that is routed to a VSL Flute. To make the sound legato there have to be an overlap between the notes, but I don't always accomplish that when I play the notes. So is there a way to select the notes in the MIDI editor and have DP8 checking to see if the notes overlap and if not extend the notes a bit to create the legato?
Mac Studio Max 64 gb, PC server 64 gb, MacPro 12 core 48 gb.
DP 11, Pro Tools 11, Logic 10, Cubase 11, Studio One 5... Waves9, All NI, All VSL, LASS 2, Brodway Big Band, UA I & II, Altiverb 7, Arturia Synths, BFD3, Sound Toys, All Toontrack, Ozone, Melodyne, Spectrasonics, UHE.....AND a Steinway Concert Grand model A.
Re: How do you create legato in MIDI Editor
One way: Use the "move releases to closest attack" command. Then use the duration command to make the notes a few ticks longer to get the overlap.
JSmith1234567
Post by JSmith1234567 »
Man...after all of these years, I wish they had something like that built-in!
Tritonemusic
Post by Tritonemusic »
bayswater wrote:One way: Use the "move releases to closest attack" command. Then use the duration command to make the notes a few ticks longer to get the overlap.
+1
JSmith1234567 wrote:Man...after all of these years, I wish they had something like that built-in!
? It is built in. It's in the Region menu.
JSmith1234567
I meant a force-legato command.
JSmith1234567 wrote:I meant a force-legato command.
How would that differ from the existing Region menu command? Or are you talking about something that would record a passage as legato in the first place?
