I use DP8 for live performance. I have approx 90 songs. All are in the Chunks window and it is a nightmare setting up set lists. Is there a way to sort, search, use keys to move chunks up and down, and save setlists? Will anything change in DP9 pertaining to this?
Sorting CHUNKS?
- FMiguelez
Re: Sorting CHUNKS?
I don't think you can do that...
Let MOTU know about your situation, so they may implement it at some point.
I would like to be able to sort my chunks...
Re: Sorting CHUNKS?
Easy.
From the Project menu, select "Chunks" or just press shift+C. Drag the chunk names up and down to rearrange in any order you like.
http://www.davepolich.com
Re: Sorting CHUNKS?
I believe you can set keys to run specific chunks.
Re: Sorting CHUNKS?
I use a coarse sieve. Most stuff will pass through except the carrots.
Don't forget the mouthwash before you resume smoochin' your new-found friend...
