AAF DP Conundrum
- supersonic
AAF DP Conundrum
Here is a typical view of what I get when I import an AAF file straight from avid.
Lots of chunks and a big mess . So what I usually do I open it in PT11 and re-export it as AAF. And that works every time.
So the big question is - what is wrong with the original AAF from Avid and what should I tell those good folks that send them to me the parameters should be so that DP understands the sequence properly.
Any ideas?
Any ideas?
Music is movement in silence
Re: AAF DP Conundrum
Any ideas?
MacPro 12core 64GB Ram 4 1TB SSDs motu 828mk3 DP 10.11
- supersonic
So the only way to do it is to go through PT?
- cbergm7210
I agree it's the only way it works correctly.supersonic wrote:So the only way to do it is to go through PT?
http://www.rfjmusic.com
- supersonic
Ok
Ive posted a few times. I have had problems with opening a OMF/AAF file in DP for years. Starts to open and then hangs and crashes.Others have posted also about problems with DP. PT has been solid for me in that department.
2009 8 Core 5.1, 2012 6 Core MacPro,s , (32 gigs Ram) Mojave 14.6, Radeon 570, MacBookPros 2011, 2017 , 828MKIII Hybrid, 828X, MicroBook II, 8Pre, Nuendo 8ch A/D converter, PreSonus DigiMax LT ,DP11 , PT 2022.12, Cubase Elements 10.5, Peak 7, Logic 9 ,WaveLab 11, Reason 10, DSP-Quattro 5 ,many plugins , mics and synths. http://www.panaccimusic.com
OMF 1 or OMF 2?
Hey Mike , what,s the difference please. All I know is when I try and open a OMF embedded 24/96 or 48 or otherwise I have had problems.
The unreliable aaf and omf (1 or 2) importing have been deal breakers for me with DP for some years. If I could be sure that it could handle anything editors throw at me, as Pro Tools does, I would have jumped from ProTools to DP years ago. I really would like to kick the Avid dependence. I really wish MOTU could get a grip on this and also provide extensive import options for omfs and aafs giving you info on the file, allowing you to select what to import, etc.
There are standalone AAF and OMF2 converters. Nothing likes OMF1 which usually includes the word "unreliable" in the same sentence.
- supersonic
It is AAF I get. For now going through PT11 works but it is just one more step to do.
I've also been having the most difficult time trying to import Avid AAFs into DP. I've gotten mixed results; DP crash; Lots of chunks, many with no soundbites in them; total success.
I'm new to the post game so I'm trying to find the best workflow. I've used DP since v2.7 and love it. I'm not that experienced with PT but from the experience I've had, I'd much rather use DP.
I agree that the problem is that 'Avid doesn't want their AAFs to work in any DAW other than PT.' I'm gonna try the PT to DP route. But I have a feeling that I'll have to become more proficient in PT and bite the bullet for the time being. I wish MOTU would be more aggressive in fixing this issue.
Supersonic, do you mind me asking what setting you're using when you import the AAF into PT?
- supersonic
You mean settings on DP side? There aren't any. Just slide the file onto chunk window. I don't know what they do on AVID side but I can check it out and experiment with different settings.
- alansende
I do a lot of mixing and sound design on DP so I frequently need to be able to open Pro Tools sessions.
I always had a lot of struggle when trying to open OMF/AAF files in DP 7.24 and DP8 (in 32bit and 64bit modes). Both importing and opening the files made DP crash at startup in most of the cases.
The only proved way I discovered recently after thousands of possible combinations and attempts to open interchange files is to create a new project and then drag and drop the OMF/AAF file inside the Chunks window. Then you can delete the empty chunk that creates automatically with the new project, save the project and start working.
I don't know what is happening internally, but I'm happy I've found a way to avoid using Pro Tools for my daily work .
www.cromomusica.com - DP 11 - Macbook Pro M2 Max 96GB Ram 2TB - Focal Trio 6BE - Avalon 747 - Universal Audio - Audient ASP800 - TC Clarity M - NI Komplete Kontrol S61 MKII - Kemper Profiler - Fender Rhodes MKI 1977 - Moog Slim Phatty - Moog Subsequent 37 - Prophet Rev 2 - DSI Mono Evolver - Fender Am Std Tele - Fender Am Pro Strat - D'Angelico Deluxe Bedford P90 - Ibanez JSM10 - Fender P Bass - Fender Mustang Vintera - Beaudoux PA1 - Taylor GS Mini - Zaor, Mixingtable & Raventos Design
- supersonic
Will try that
