track selection in sequence editor
I've been slowly re-adjusting to the DP way of doing things since I got back into it so forgive me for this. There is one area I can't seem to figure out and it should be dead simple and that is multiple track selection in the sequence editor. I can't seem to be able to select multiple tracks via click and drag like in the tracks overview. Or click on one track, hold down the shift key and click on a track further down the screen and select all the tracks between the two clicks. Is this not doable in the sequence editor?
The only way I can make multiple track selections is to hold down the command key and click on every track.
Re: track selection in sequence editor
Works here. If you are in the tracks overview, click and hold on one of the track names and drag downward.
In the sequence editor, open the track selector via the icon in the lower left. Here it is a little different. Clicking toggles tracks on and off. Option-clicking selects a single track and deselects all others. Command-clicking deselects that one track and enables all others. And as in some things, Shift-click works the way command-click works in most other OS contexts, it adds each track to selections or toggles them on & off.
I don't want to show or hide tracks I want to be able to select tracks like you can in the track overview so one can do things like create a clipping or other use. But it doesn't seem like that can be done. Your method won't do that - it'll just show or hide them.stubbsonic wrote:Works here. If you are in the tracks overview, click and hold on one of the track names and drag downward.
Command Click the track names.
As far as I can tell, shift-clicking blocks of tracks doesn't work in the sequence editor, only in the tracks overview. At least I've never gotten it to work. You can, however, have both windows open and make your selection in the TO which will also select those tracks in the SE.
You can also click-drag across tracks with the pointer tool, but you have to start your drag somewhere where there's no soundbite (like at the end of the sequence), or else you'll likely be dragging a soundbite out of place.
Phil
Phil
This little trick is for the Sequence Editor only:
Hold down the Control Key while selecting data. You can then drag over multiple tracks, including grouped tracks (grouped for selection, the entire group will select in the range you're dragging), and keep dragging to include other tracks (or groups).
This is a range-selection only. It will not move your soundbites by accident.
Also, since you brought up the Tracks Overview Window, this is a good time to repeat the tip about dragging in that window:
• In the Tracks Overview Window, each cell is divided top/bottom with differing selection types, depending on where your drag/click originates.
- — If you click & drag in the top part of any cell, you can drag a range selection over any number of tracks.
— If you click & drag in the bottom part of any cell, you can drag a range selection, but it will be constrained to the track in which you clicked. (Grouped tracks will select together)
— Click & release upper portion of cell ("+" cursor) to select a cell. Hold Command Key to insert vertical line at cursor (one boundary of a range, or a point for splitting tracks, etc.)
— Click & release lower portion of cell (arrow cursor) to select a region. Add more tracks by Shift-Clicking regions or track names.
Command Key generally releases the range constraints and enables selection to start anywhere.
I know that but that only works for one track at a time. You have to hold the cmd key down and click on each track to have multiple tracks in the selection which is a right pain and not following normal selection routines.bayswater wrote:Command Click the track names.
This only selects tracks that have data in them and not all tracks I'd want to select would have data in them all the time. I have a piece I'm working on (1812 Overture) and as you know not all the tracks play at the same time. So if I start making a selection on a track that has data but the next one doesn't (but I still want to include that track in the selection) but the track after that one has data at the point of the selection the track in the middle doesn't show as selected.Shooshie wrote:This little trick is for the Sequence Editor only:
I really don't want to have to switch between windows just to make a selection of a group of tracks if I can help it. I prefer working in the sequence editor when I can.
Using the Shift Key along with the Control Key you can come up with odd selections like this:
I can only think of a couple reasons for such a selection right now, but it's nice to know it's there.
musicman691 wrote:This only selects tracks that have data in them and not all tracks I'd want to select would have data in them all the time. I have a piece I'm working on (1812 Overture) and as you know not all the tracks play at the same time. So if I start making a selection on a track that has data but the next one doesn't (but I still want to include that track in the selection) but the track after that one has data at the point of the selection the track in the middle doesn't show as selected.Shooshie wrote:This little trick is for the Sequence Editor only:
MIDI is for the MIDI Editor. You do what you like, but ask yourself if you're doing it because you prefer the Sequence Editor, or because you're not familiar enough with the MIDI Editor. The only time I do MIDI in the Sequence Editor is when I need to align it with Audio, visually. Actually, there are a couple other reasons, but I can't think of them right now. They don't pop up enough to warrant regular usage there. That's all I'll say about that.
As for the areas with blank tracks, that's a problem for what you're doing. But you CAN work around them using the Shift Key in addition to the Control Key. But if you happen to release the mouse over a blank track, BOOM... there went your hard-won selection. Still, if you are careful, that shouldn't happen.
A better work-around is to learn the command for Range Selection Only. I have mine set as follows:
- • CONTROL-OPTION-SHIFT-[9] = Time Range Selections Only
• CONTROL-OPTION-SHIFT-[8] = Event & Phrase Selections Only
• CONTROL-OPTION-SHIFT-[7] = All Selections
There are other cases where this works to your advantage, so it's not a bug. I would not want to change it, at least not at this point, and not without addressing those working methods where it becomes advantageous. But if you just switch to Time Range Selection Only, you'll get what you want. Just takes a key-press. Then another when you want to switch back to Event & Range Selections.
So, when using Range Selections, it DOES do what you want, exactly.
Rereading the posts, I don't know where I got the MIDI thing. For some reason I thought you mentioned working with MIDI in the Sequence Editor in your previous post. It's not there. (cue Twilight Zone Theme)
Anyway... I'll leave what I said. Just ignore it if it doesn't apply.
Shoosh
Shoosh
Since we've evolved to selecting Range Selections Only, you don't need the Control Key to drag over any given range. Just drag. SHIFT-Drag for disjointed selections. Once more, here are the settings I have for switching selection types. I don't know if they are defaults, or if I set them that way long ago, but that's what I've been using for a long time:
- • CONTROL-OPTION-SHIFT-[9]* = Time Range Selections Only
• CONTROL-OPTION-SHIFT-[7] = All Selections- *[keypad]
Nevertheless, it is how you select multiple tracks in the Sequence Editor. What you want to do is better done in the Track Overview.musicman691 wrote:I know that but that only works for one track at a time. You have to hold the cmd key down and click on each track to have multiple tracks in the selection which is a right pain and not following normal selection routines.bayswater wrote:Command Click the track names.
One thing to consider is learning the differences between the Track Overview and the Sequence Editor and make selective use of their features. A lot of people, particularly those switching from Cubase and Logic, think they are just two unaccountably odd and different views of the same thing, and suggest the TO is best eliminated. But for better or worse, somethings are better done in one than the other. Deciding how to split functions across the two is a part of setting up a workflow that's best for you. I'd go so far as to say that DP doesn't work well for those who don't develop a structured approach.
I use the TO for setting up signal paths (after setting up Bundles), colour schemes, templates, and general layout. I keep the SE for things where I'm going to focus on a few tracks and the way audio is arranged, and over time, use it less and less in favour of the TO and MIDI Editor. But everyone will approach this differently.
Somethings may be better done in one versus the other but that's no excuse for not being able to use normal selection routines in the sequence editor window. I'm really not that nuts about doing a lot of work in the TO; I can see more of what I need in the SE. I also find it easier for setting things up like paths and such as it allows me to see things in a top down manner much easier. But then again each of us works in a different manner.bayswater wrote:Nevertheless, it is how you select multiple tracks in the Sequence Editor. What you want to do is better done in the Track Overview.musicman691 wrote:I know that but that only works for one track at a time. You have to hold the cmd key down and click on each track to have multiple tracks in the selection which is a right pain and not following normal selection routines.bayswater wrote:Command Click the track names.
