Lock tracks to each-other / stems
JSmith1234567
Post by JSmith1234567 »
I would love to have a way to lock audio tracks to each-other and edit them en-masse.
When we are moving and editing stereo and surround stem-mixes to new picture-cuts, there is quite a bit of editing.
You don't want stuff getting out-of-phase if it is slightly nudged.
If you could just lock sets of tracks to other tracks and edit them together, music-editing for picture would be so much easier.
philbrown
Re: Lock tracks to each-other / stems
Post by philbrown »
Track groups.
JSmith1234567
Am I missing something with that?
Open the fit window, it doesn't lock tracks to each other in the timeline for editing.
Is there another way to do this?
Gravity Jim
Post by Gravity Jim »
He means "look up 'track groups' in the manual."
You're not finding this feature because of terminology meltdown. You don't "lock" tracks together ("lock" refers to a whole other set of time controls), you "group" them (and then whatever you do to one track in the group gets done to all of them).
Jim Bordner
JSmith1234567
Hey man…I'll try this.
Just dragging a track in the editing window, after I grouped them, does not drag the other tracks.
Maybe I'm doing something wrong here?
If I understand what you're trying to do, I don't think DP can do it. Just grouping tracks won't anyway. Maybe you can get something like it:
- extract a groove from one of the tracks and apply it to the others.
- build a tempo map from one track and quantize the others to the tempo that results. Alternatively, chop up the audio and quantize the soundbite sync points.
- if there aren't a lot of tracks to deal with, dump them all into a surround track and edit that
Logic X has a feature that defines one of the tracks as the timeline and controls playback of the others, but it doesn't seem to work that well. It gets closer to what I think you want to do, but DP can more or less so the same with the first two options above.
Tim
Post by Tim »
Selected soundbites should move around together and stay in perfect sync. When Grouped (and the proper grouping parameters are selected... like Edit mode), clicking on one soundbite in the group will select all others that start and end at the same time. If the soundbites do not all start and end at the exact same points, clicking on one will not select all the others in the group... shift-click.
Post by Rick Cornish »
Not sure if this helps you: In the Tracks Overview, clicking in the horizontal bar for the track folder selects all the tracks within that folder.
philbrown
Post by philbrown »
I must not be understanding the original question. As I understand your post, Track Groups will do exactly what you're asking. I use them all day along exactly as (I think) you're describing. DP8 manual p163-165, specifically Edit Groups on p165. If that doesn't answer your question, please post what it's not accomplishing that you want to do and maybe we can sort it out.
Gravity Jim
Yeah, if that's not working, they're not grouped. Double check your findings...
Jim Bordner
JSmith1234567
Maybe I'm on crack…but…
Select two audio tracks.
Group them as a new group, and make sure the group is enabled.
Open the edit window
Drag just one of the tracks in the editor.
Does the other track move too?
JSmith1234567 wrote:Maybe I'm on crack…but…
Maybe the step you're missing is where you customize the group settings. "Selection" is one of the items you can check in the list. And yes... they all move together.
Here are the settings in the list:
You can see what the options are. To open this window, you must click on the group type in the right-hand column of the group window.
frankf
Post by frankf »
the OP IMO is asking two different questions or asking one that is really two. maybe he can clarify which of the following he's asking about.
If DP has:
1. The ability to MOVE selected tracks with all their data to a different place in the track list. Multiple selected tracks cannot be moved simultaneously by dragging. There are Move commands that he can use, however. One is Move selected tracks to be together. Check the commands window.
2. The ability to Edit data in selected tracks simultaneously. This is done by grouping the tracks and checking the Editing box as others have described.
Frank Ferrucci
Frank Ferrucci
http://www.ferruccimusic.com
I took the question to be about whether DP can edit multiple tracks in a manner that one might use to deal with drum tracks, "locking" them together to avoid phasing that might result from moving or stretching them.
frankf
Post by frankf »
Me too, but he says "when MOVING and editing...' ( my caps)
Frank Ferrucci
Frank Ferrucci
