displaying 2 mixing boards?
csavetman
Post by csavetman »
So I'm attempting to display 2 separate mixing board windows for 2 sequences inside of a single DP project. I'd like to drag some track plugins from one sequence mixer to the other, and I didn't initially put those plugin inside a clipping window.
Is this even possible? I can display 2 track overview windows simultaneously, but with the mixing board window, it seems to switch back to one sequence or the other.
Any ideas?
thanks
Carlos
Using DP 8.07 / Mac Dual quad core xeon / OS 10.8.5
Re: displaying 2 mixing boards?
If you still have the original sequence with the plugins to be copied, you can still use clippings to copy them over to the new sequence. You can also use Insert Settings.
