Expert Sleepers Silent Way Sync Issue
pencilina
Post by pencilina »
Hi All,
For some reason my SW sync plugin seems to be skipping a beat every intermittently 4-16 bars. Is anybody else experiencing this or using SW sync successfully in DP? SW sync doesn't seem to have this problem in other hosts. No loops- 4/4 time.
Thanks,
Bradford
philbrown
Re: Expert Sleepers Silent Way Sync Issue
Post by philbrown »
I wish I could help you. I did a lot of this kind of stuff with my modular synth with both Volta (buggy) and syncing straight from DP to analog via 24io, but I never used Silent Way. I suspect there are only a handful of people here that are familiar with Silent Way. Are you on the Muff synth group? Expert Sleepers has a sub-group there and Os may be able to help you directly or maybe there's a helpful thread there already. I'm doctor vague on the Muff group.. FWIW I had issues with Volta>DP that I never resolved, so it may be a DP issue, but I realize that doesn't help you at all. IIRC correctly os (username) real name is Andrew Ostler and he's a super guy, very helpful.
https://www.muffwiggler.com/forum/viewf ... cde7223131
If you don't mind me asking, what exactly are you trying to do?
pencilina
Post by pencilina »
Hi Phil,
Thanks- Yes, I posted to muffwiggler as well and called and reported the problem to Motu. In the end I'm very happy the sync didn't work as I came up with a workaround sending looped MIDI notes through trigger plug ins to use as clock pulses for analog gear,a korg sq-1 and a korg mono/poly arpeggiator. (MIDI->sw trigger->RME adatout out->standalone traveler->synth sync/clock ins). The very cool thing about that is that I can quickly mess with the rhythms of the clocks. Except for that Silent Way seems to work very well through my traveler. I'm really having fun and finding some new places to go in analog land.
Best,
B
philbrown
Post by philbrown »
pencilina wrote:Hi Phil,
Best,
B
That's exactly the kind of thing I was thinking of. I used to send a bunch of sync pulses direct from DP (as audio not MIDI) using flat line 5ms WAV files out of a 24io and then select them at the modular and further process with a Moon trigger sequencer. Great fun! I wrote a long article about all that on Muff's years ago, but the pics all got hosed when iDisk went up in smoke, so it wouldn't make much sense now, but I dove in really deep into this whole area. Definitely enjoyed the tight timing of using audio sync vs MIDI for such things. I sold my modular and all my cool analog gear like an idiot and miss it like crazy these days. Check out my doctorvague videos sometime, if you're interested, especially this one as far as sync goes- where I'm sending 4 pulse trains out of the 24io into a DIY matrix switcher and on to the modular:
https://www.youtube.com/watch?v=87hR0hLZqpk
pencilina
Post by pencilina »
Cool.
What a very nice processed bossanova!
