How to set default for Markers to Locked
JZilla
Post by JZilla »
Hey folks. I've just had an issue where my preferences were lost, and it's been so long since I've done this that I don't remember how to do it. I'd like to have the default for a new marker be in the locked state, can anyone point me in the right direction?
Thanks.
2019 MacPro, 10.15.5, 16 core 3.2 GHz, 384 GB RAM
DP 10.11
Kontakt 6.2.2, Spectrasonics, u-he, Arturia, NI Komplete 11, VE Pro
UAD, Waves, Soundtoys, Slate, FabFilter
Re: How to set default for Markers to Locked
Open the Markers Window (SHIFT-K), and in the Mini-Menu is a "New Marker with options..."
Here you can set this as a locked marker.
In the Commands list, there is a "New Marker with Options" so you would be setting your marker shortcut to trigger this.
JZilla
Post by JZilla »
Yup, tried that, even when adding a Marker with options, it defaults to being unlocked. I know I had it set before so that all markers added with options were locked, it's just not happening now and I can't remember where I can fix it. Obviously I can always lock them after the fact, it's just one additional (and unnecessary) step.
DP 10.11
Sorry about that red herring.
I found it. Go to Preferences, and in the PLAY & RECORD section there is a page for Film Scoring Events. You can enable "New Markers are locked".
JZilla
Post by JZilla »
Aha! That did the trick. Thanks for figuring it out, I probably would have found it eventually, but the help's much appreciated.
DP 10.11
