Send Levels default to minus ∞ ?!
Hello everyone!
I'm looking into changing from PT to DP. So i'm i total newbie. Trying to watch tutorials and reading the manual as we speak. However, i couldn't figure out how to configure my sends to minus infinity. AFAIK, it's not even mentioned in the manual. Or i'm searching in the wrong spot.
Could someone please help?
- FMiguelez
Re: Send Levels default to minus ∞ ?!
A lot of us have been asking for that behaviour to change, but we´ve had no luck thus far. As of now, DP defaults its new channel sends to unity.
-You can create a channel, set its sends to minus infinity, and duplicate your tracks from there as needed.
- Or you can use a template or clippings that were previously set to the way you like.
- Or you can show all your tracks in the mixer, and by pressing and holding letter w, you can set ALL the channels´ sends in one fell swoop.
Not the ideal thing, but at least we have very quick work arounds.
Thanks for your reply - i guess i can make do with a template.
The w-key curiously only works with faders, but not with send levels. Where might the problem be?
- FMiguelez
Make sure the sends is checked as an option in the Group Settings box (you can look for the command in the Commands Window - Shift-L).
There´s an option to default the temporary groups (accessed by holding the w and t keys) to whatever you select in there.
Thanks a lot mate! Works
Can someone elaborate, if there's a way to change all sends in a row to Pre-Fade? Another thing i just can't find, is how to insert the same plugin to multiple tracks. Any inputs?
thanks
thanks
- FMiguelez
I'm glad you're enjoying that featureTinu_CH wrote:Thanks a lot mate! Works
If there's no parameter for it in the temporary Groups window, then I don't know if it's possible.Tinu_CH wrote:Can someone elaborate, if there's a way to change all sends in a row to Pre-Fade?
But a well though-out template could resolve that.
Not like a global command, but an easy way to achieve this is to duplicate the plug from another channel (or your presets menu). You do this by option-dragging plugins between channels and rows. This duplicates them. Note that it can be done individually or with full chains of plugs.Tinu_CH wrote:Another thing i just can't find, is how to insert the same plugin to multiple tracks. Any inputs?
Clippings are another option (you can access them at the top of the mixer menu).
