question about moving to 64 bit architecture
- donreynolds
I have progressed from 32 bit to 64 bit. Is there anything special that I need to do with my computer for DP? Do I need to upgrade from 7.24 to 8?
I know I am going to have to go through all my plugs and get any new updates for compatibility for Osx 10.8.5 and this computer I assume.
Well, I downloaded the Ilok manager and it shows all my plugs on my Ilok but DP is not recognizing the ILOK??
Now sure how to make sense of the new ILOK manager window. It says I have all my plugs activated on my ILOK2 in the left pane, but none are available on my computer? ( 0 activations)
My ILOK is lit up and connected in the same USB slot it always has but the computer will not recognize it.
any ideas guys?
any ideas guys?
DP 9, MacPro 2.93/8 core/22 Gb RAM. OS X 10.11.6, 13"Macbook PRO 2.66 Duo, OS 10.11.6 El Capitan, 2xWD 150gig Raptor x 2, x3 My Book Studio 1 & 2Tb drive x 2, DP 7.24, BLA/Motu 896 HD x 2, BLA microclock ll, Presonus Central Station, Waves Plat. V7 , Slate Everything, Melodyne studio, SSD 5, TruePianos, Scuffham S-Gear, Alpha Track, Event 20/20 bas, Adam A7, and other toys, Lotsa guitars, HeadRush GTR processor and a Korg Triton)
Re: question about moving to 64 bit architecture
7.24 is not 74 bit AFAIK. So if you have 64 bit plugs they likely won't show up. It may be that simple.
- donreynolds
I see. Thanks. So I guess I need to move up to DP 8 for compatibility?
If you want to use 64 bit, I'm 99 and 44/100% sure.
- Shooshie
That sounds like the incredible piano sample library, Dial, the 99 and 44/100% pure piano library. The other 36/100 of a percent is full of Lava.MIDI Life Crisis wrote:If you want to use 64 bit, I'm 99 and 44/100% sure.
Yes. If you upgrade to 8 now, you will get DP 9 when it ships at no extra charge.donreynolds wrote:I see. Thanks. So I guess I need to move up to DP 8 for compatibility?
http://youtu.be/H121anenyacShooshie wrote:That sounds like the incredible piano sample library, Dial, the 99 and 44/100% pure piano library. The other 36/100 of a percent is full of Lava.MIDI Life Crisis wrote:If you want to use 64 bit, I'm 99 and 44/100% sure.
- donreynolds
Hey, thanks MDL for your advice. It is very much appreciated. you guys sure know what you are talking about.
