Is it my imagination, or has the functionality of the counter window changed?
I seem to remember that you could have it set differently than the control-panel window?
When I try to change it in its's mini-menu from measures to frames, it changes both the control-panel and the counter window.
Am I doing something wrong?
It seems like they used to be independent?
Counter Window Indepedance
Re: Counter Window Indepedance
Not sure what version of DP or OS you are using, but on OSX DP8.06 the counter (can be) different. It depends on which counter is set to "main". Here's mine:JSmith1234567 wrote:Is it my imagination, or has the functionality of the counter window changed?
As you can see, my main counter is Real Time and the control panel is Measures. Display of the other types is optional.
Hope this helps.
Chuck
iMac (Retina 4K, 21.5-inch, 2017)|| 16GB Ram || OS/X 10.14.6 || Motu 828MkII || Steinberg UR242 || DP8.07
Macbook Pro (Retina, 13-inch), 2.7 GHz i5, 8GB Ram
Chuck
