I'm editing some drums.
Using the scissor tool on a single track is great, but, is there a way to get the scissor tool to "cut" all the tracks within a group?
i.e. I click to cut the Kick Drum track and all the tracks within the drum group get sliced as well.
Scissor Tool to cut all audio within a group?
Dual Quad-Core 2.8 GHz Mac Pro 3,1 • Yosemite • 24 GB RAM • MOTU 2408mk3 (x's 2) • DP 10.xx • Finale 25 • Logic • PT 12 • +outboard gear
Re: Scissor Tool to cut all audio within a group?
Yes. Just select the tracks you want to cut. Cut one, and they all should cut in the same place.
I must be doing something wrong or have a group parameter set wrong. I'll try again.
For audio, I think you have to select the soundbites, not the tracks. You can also use Split at counter.
Doh! Soundbites! I meant the soundbites!
