Adding Document into Session?
- csiaudio
- Location: Indiana; Where the corn is tall and the women are wide!
I doubt this is a current or will be a future function of DP8 but does anyone know if it's possible to attach or add a Word doc into a session? So that when the session is opened up at a later date it will still have the Word doc attached into the session?
Capturing the Colors of Sound!
Mac Mini M1 2020 -- DP 11.2 -- Universal Audio Apollo Quad -- Apollo Twin -- SPL Kultube Compressor -- Slate Virtual Mic -- Eve SC207's w/KRK Sub
Re: Adding Document into Session?
EDIT: I stand corrected. Thanks Shooshie.
Last edited by MIDI Life Crisis on Wed Feb 04, 2015 3:39 pm, edited 1 time in total.
Well, there is the "New Startup Clipping Window" or "New Project Clipping Window" feature. Can't exactly remember which one it was...
I used to use it to open TextEdit or Preview, in conjunction with certain DP files.
I think I included it in the DP Project folder and then zipped it (like MLC mentioned).
I'm still on DP 7.24.
Startup ClippingsTritonemusic wrote:Well, there is the "New Startup Clipping Window" or "New Project Clipping Window" feature. Can't exactly remember which one it was...
"New Startup Clipping File" opens a window. You drag in the file or app. It doesn't matter what it is, as this is just a folder that DP tells to "open all" when it's starting up. And that's all there is to it.
