Splitting Drum Track
I'm sure this has been asked before but I couldn't find it on here...! I have a MIDI drum track that was sent to me all in one track in GM drums and want to separate out each drum as its own track, but keeping the velocity, etc., for each "drum/note" when it's sent to its own track. Is there a simple way to do this in DP8?
Thanks!!
- Jacki
Thanks!!
- Jacki
Re: Splitting Drum Track
Check the manual for "Split Notes."
- SMS
In the MIDI editor, you can double-click a particular note on the 'keyboard' to the left, that will select all instances of that note in the track. Cut, then paste to a new track. Simple.
MOTU user since Performer™ 1.22 on 128k floppy
DP 11.23
MacBook Pro 14” 2023 M2 max 12 core
64 Gb RAM
4TB SSD
OS 14.0 Sonoma
UAD Apollo 8
828 mk3 Hybrid
MIDI Express XT
DP 11.23
64 Gb RAM
4TB SSD
OS 14.0 Sonoma
UAD Apollo 8
828 mk3 Hybrid
MIDI Express XT
Yes, but Split Notes will do it in one fell swoop. Even simpler.SMS wrote:In the MIDI editor, you can double-click a particular note on the 'keyboard' to the left, that will select all instances of that note in the track. Cut, then paste to a new track. Simple.
+1Tritonemusic wrote:Yes, but Split Notes will do it in one fell swoop. Even simpler.
- SMS
Hmm- I just tried it, and didn't realize Split Notes could create a separate track for each note- Cool! How long has that been there (I started with version 1.22 of Performer™)?
DP 11.23
64 Gb RAM
4TB SSD
OS 14.0 Sonoma
UAD Apollo 8
828 mk3 Hybrid
MIDI Express XT
DP 11.23
64 Gb RAM
4TB SSD
OS 14.0 Sonoma
UAD Apollo 8
828 mk3 Hybrid
MIDI Express XT
Pretty cool, huh? Probably been there that long. I remember using it in System 6 on my Mac Classic.SMS wrote:Hmm- I just tried it, and didn't realize Split Notes could create a separate track for each note- Cool! How long has that been there (I started with version 1.22 of Performer™)?
The Drum Editor can be your friend here too.
Babz
WOW!!! That is AWESOME!! Thanks so much, everyone
- toodamnhip
The only problem with spilt notes can be when and if it interprets a controller as a separate note, at which point you have to be careful to ensure that controller gets sent to the right MIDI module, for example, hi hats often have data re op Ning and co trolling if a hat, split notes leaves a user with that controller data separated from the hi hat notes
Mac Pro (Late 2013
2.7 GHz 12-Core Intel Xeon E5
64 GB 1866 MHz DDR3
Mojave
DP 10.13
MOTU 8pre, MTP AV, 828 mkII
64 GB 1866 MHz DDR3
Mojave
DP 10.13
